-   -   QUICK Scheme (http://www.cfd-online.com/Forums/openfoam-solving/70835-quick-scheme.html)
mmahdinia December 7, 2009 15:10
QUICK Scheme
Hi Foamers,
I am using the LES solver to solve a variable density problem, which is of course not compressible. Anyway, the point is that when I use the following gradient scheme, I get an error of "segmentation fault":
gradSchemes
default Gauss QUICK phi;
grad(p) Gauss QUICK phi;
grad(U) Gauss QUICK phi;
Anybody knows what the problem is? Any help would be appreciated.
Maani
linnemann December 9, 2009 10:03
Hi
The error output would be very helpful. And maybe a better description of the physical problem you are solving.
mmahdinia December 9, 2009 17:27
Case under study
Originally Posted by linnemann (Post 239291)
Hi
Hi Linnemann,
Thanks for the reply. The case is that of a density current, in which a fluid of a higher density is released under an another low density fluid. The difference between their densities creates a shear layer between them and this results in a turbulent flow in common interface.
I am using the LES solver (dynamic smagorinsky) plu vanDriest delta, and I have added a code to solve for the variable density there. When I choose the QUICK scheme for the gradient, before the first time step, the code gives:
Time=0.01
segmentation fault
and that's all. You might want to try it yourself!? Any help would be appropriated of course.
Yous sincerely,
Maani
mmahdinia December 9, 2009 17:30
A thing
Well, I forgot to ask but it would be great if you could give me an idea about the following parameters: 1) max cell expansion ratio in B.L. 2) max cell aspect ratio 3) max Courant number
Yours sincerely,
Mani
