-   -   Turbulent flow of two incompressible fluids with the same physical properties (http://www.cfd-online.com/Forums/openfoam-solving/70959-turbulent-flow-two-incompressible-fluids-same-physical-properties.html)
ArneBab December 10, 2009 12:07
Can OpenFOAM simulate the injection of two different incompressible fluids with the same physical properties (when it comes to fluid dynamics), including turbulent flow. Can it output the result in a way which allows me to visualize the fraction of the fluids at every point?
I've been testing OpenFOAM the last two days, but I didn't find a clear answer (neither here nor via Google).
I looked at the sloshingTank3D (interDyMFoam) and the elbow (icoFoam), as well as some others. What I couldn't answer for myself:
* Can I add injection of a specific fluid instead of setting a general velocity field?
* Can I "tag" a fluid, so I can identify it in ParaView?
* Does both work with turbulent flow?
(I currently evaluate different options for simulating contrast fluid in blood vessels)
mprinkey December 10, 2009 14:46
Originally Posted by ArneBab (Post 239509)
If the two fluids are hydrodynamically equivalent, there is no need to treat them as separate. Just use a passive scalar field as a marker and advect it using the normal phi in the convection terms. You can compute the effective diffusivity for the scalar based on the turbulent viscosity. Start with a transient, turbulent solver and add a passive scalar equation. It should go into the code after the PISO/pressure correction loop completes, so the flux field is conservative.
ArneBab December 11, 2009 04:32
Hi mprinkey,
Many thanks for your answer!
I now played a bit with a passive scalar field, and it seems to do exactly what I need.
Just to be sure I don't go into completely unrelated directions: Did I understand you correctly, that the next step now is to grab the source for a turbulent solver (for example turbFlow) and add the passive scalar equation (for example taken from the scalarTransportFoam)?
Best wishes,
Arne
ArneBab January 5, 2010 05:48
found
I now found the second answer myself - two weeks winter vacation and google helped -> yes, I have to build my own solver (turbulence + scalar field). And it doesn't seem horribly complicated - means I found a guide which shows the basics:
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
Many thanks!
