Is that a checker-boarding pattern? How to avoid it?
Old   December 10, 2009, 06:02
Question Is that a checker-boarding pattern? How to avoid it?
Robert Castilla
rcastilla is on a distinguished road
I am simulating internal turbulent flow in complex geometries with simpleFoam and k-Omega SST, and I have found this strange behavior (see attached picture).
The fvSolution and fvSchemes files are:
solvers
p
solver GAMG;
tolerance 1e-7;
relTol 0.1;
// preconditioner DIC
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
U
solver smoothSolver;
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
k
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
omega
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0;
relaxationFactors
p 0.3;
U 0.7;
k 0.7;
epsilon 0.7;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
// grad(U) Gauss limitedLinear;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV cellLimited Gauss linear 1;
div(phi,k) Gauss upwind;
div(phi,omega) Gauss upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
// default Gauss linear limited 0.5;
// default Gauss linear limited 0.333;
interpolationSchemes
// default upwind phi;
// interpolate(U) upwind phi;
default linear;
interpolation linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
I am not sure if it is the checker-boarding pattern. If it is, it should be avoided with SIMPLE, isn't it? Maybe have I to tune the SIMPLE parameters? Can somebody give me some hint?
Thank you
Robert
rcastilla is offline   Reply With Quote
Old   December 10, 2009, 08:45
Robert Castilla
I am trying with pisoFoam (transient solver) and results are not better.
Old   December 11, 2009, 11:50
Robert Castilla
It seems so be related to mesh. It has been meshed with snappyHexMesh. If there are sharp transitions of cell size, this kind of patterns arise. I don't know the reason, but I have tried with a regular (not grading) hexahedral mesh, it went fine. Maybe it is something that only happens when meshing with snappyHexMesh inan internal flow.
Flow pattern in a Nozzle sean Main CFD Forum 0 February 2, 2009 04:36
how to avoid self intersection:Proam bala Siemens 5 March 6, 2008 04:23
creat a pattern in DesignModler Jan CFX 2 June 11, 2005 23:38
Egyption Pyramid with All HEXA Selina Tracy Main CFD Forum 17 March 30, 2001 04:15
The Effect of impeller type on flow pattern lee ji hyun Main CFD Forum 1 January 26, 2000 08:35
