smoothSolver diverges - solution in using PBiCG solver? |
December 15, 2009, 15:49 |
Hi all!
I have 2 points to discuss: 1st one: I wrote a heat transfer solver based on pimpleFoam, adding heat transfer equation. I use high Courant numbers (up to 5) to speed up calculations. Flow simulation runs without problems (GAMG solver for pressure, smoothSolvers for U and turbulent parameters). By analogy I used smoothSolver also for TEqn in my solver: Code:
T { solver smoothSolver; smoother GaussSeidel; tolerance 1e-05; relTol 0; nSweeps 1; } Then I just switched TEqn solver to PBiCG with DILU preconditioner Code:
T { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0; } So what is the reason for such behavior? 2nd point: Why am I using pimpleFoam? I solve more complicated task with solidification and turbulent flow. For some cases I search for steady state. One approache is to use steady state solvers, another - to apply transient or cvazi-transient solvers to reach steady state when solution will become stable. I tried to use simpleFoam just to test such posibility for my task. It reached solution which transient solvers achieve and do not change later, but instanteniously solution deverged! Residuals got a big jump and solution crashed... Am wondering why it happend? Stable solution for that simmetric geometry which I used was assimetric, because there are 3 jets and in 2D they cannot be stable because two zones of low pressure do not have a connection. Is assymethry of solution the case for steady state solver to deverge? So now I an forced to use PISO or PIMPLE technics to solve my problem... But it is time-consuming! So, waiting for your opinion! Have a good day!
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
August 20, 2013, 17:22 |
Jackie Chou
Hello, Dr. Alexander VAKHRUSHEV,
I have met the same situation as you had. Have you got an idea about it? Jackie |
August 21, 2013, 12:17 |
Hi Jackie!
My post was from 2009, since that OpenFOAM improved a lot in numerics. So I do not observe that now in my simulations... Sometimes under-relaxation really helps to avoid simulation from explosion. Cheers, Alexander
September 11, 2013, 13:44 |
Multigride
Hi Dr.Alexander
Can you tell me what the difference is GAMG algorithms algorithms AMG? THANKS |
coupled solver (again) | lucioantonio | FLUENT | 0 | April 8, 2009 17:15 |
Coupled solver energy equation problem | lucioantonio | FLUENT | 0 | April 3, 2009 11:21 |
two-phase Riemann analytic solution or solver. | jinwon | Main CFD Forum | 0 | July 12, 2007 23:09 |
Doubt on Implicit Methods | analyse In India | Main CFD Forum | 10 | March 9, 2007 04:01 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
