Strange Velocity in impeller of MRFSimpleFOAM
Old   April 10, 2008, 03:44
Default Hi every one i am trying to
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi every one
i am trying to simulate the centrifugal impeller with MRFSimpleFoam. after about 5000 steps there are strange velocity in only one passage,the velcity is much larger(above 1e +6 m/s).
here is the image of vector plot
waynezw0618 is offline   Reply With Quote
Old   April 10, 2008, 04:10
Default and here is the residual http
wayne.zhang
Old   April 10, 2008, 05:00
Default Take a look at k and epsilon r
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Take a look at k and epsilon residuals and see which starts to diverge first (U, k or epsilon). Then decrease de order of discretization (take upwind for example) for that particular equation.
To be on the safe side use upwind for all of them.
Dragos
dmoroian is offline   Reply With Quote
Old   April 10, 2008, 05:56
Default Hi Dragos i will try it today
wayne.zhang
Hi Dragos
i will try it today
and here is the p k and epsilon
thanks
wayne
Old   April 10, 2008, 06:04
Default Well Wayne, It seems that k a
dmoroian's Avatar
Dragos
Well Wayne,
It seems that k and epsilon are ok, you have to see which starts to diverge first: pressure equation or momentum?
Dragos
Old   April 10, 2008, 06:40
Default Hi Dragos it looks like there
wayne.zhang
Hi Dragos
it looks like there are the same
and it quit similar to the iteration procedure in cfx(i will post later,for i am not working on that computer),but there is no such strange velocity.
thanks
wayne
Old   April 10, 2008, 06:49
Default Hmm, to me it looks that press
dmoroian's Avatar
Dragos
Hmm, to me it looks that pressure starts to diverge first. So you can try to converge better the pressure equation.
Old   April 10, 2008, 07:46
Default Hi Dragos how to? would you
wayne.zhang
Hi Dragos
how to? would you mind to tell me more ?
wayne
Old   April 10, 2008, 07:56
Default Hi Wayne, Is your outflow b
lillberg's Avatar
Eric Lillberg
lillberg is on a distinguished road
Send a message via Skype™ to lillberg
Hi Wayne,
Is your outflow boundary the one in the picture or does it only show a part of the whole model. If it is your outflow boundary, what boundary conditions have chosen for it?
Also, post an image of your mesh or the output from the checkMesh utility.
Regards
//Eric
lillberg is offline   Reply With Quote
Old   April 10, 2008, 08:05
Default I use this seting for the pres
dmoroian's Avatar
Dragos
I use this seting for the pressure equation (fvSolution):
p PCG
<blockquote>preconditioner GAMG
<blockquote>tolerance 1e-6;
relTol 0.05;
smoother DICGaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
nBottomSweeps 2;
cacheAgglomeration false;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
tolerance 1e-6;
relTol 0.05;
maxIter 100;</blockquote>
</blockquote>
Old   April 10, 2008, 08:25
Default To Eric: i use the fixedValue
  #11
wayne.zhang
To Eric:
i use the fixedValue in p for my output condition. the calcualtion region is a impeller without the voulte,so you can see them on the first image!
Wayne
Old   April 10, 2008, 08:27
Default To Dragos thanks! i will
  #12
wayne.zhang
To Dragos
thanks!
i will try!
Wayne
Old   April 10, 2008, 09:27
Default Wayne, Your outflow boundar
  #13
lillberg's Avatar
Eric Lillberg
Wayne,
Your outflow boundary is way to close to the region where things happen to allow for fixed pressure BC. Use totalPressure BC instead together with appropriate BC's for U pressureInletOutletVelocity, k inletOutlet and epsilon inletOutlet.
Regards
/eric
Old   April 10, 2008, 23:50
Default Hi: i try to run the case in
  #14
wayne.zhang
Hi:
i try to run the case in the parallel again without change anything in fvSolution.i still get a divergence. but the different is i donot get strange velocity like before,and the velocity is also looks quiet strange.it looks like that there is no velocity inlet just angular velocity everywhere including the velocity inlet.
Old   April 10, 2008, 23:51
Default and is the velocity in 0.5 spa
  #15
wayne.zhang
and is the velocity in 0.5 spanwise
Old   April 10, 2008, 23:53
Default and the velocity in 0.5spanwis
  #16
wayne.zhang
and the velocity in 0.5spanwise in CFX
Old   April 11, 2008, 02:45
Default Hi Wayne, Surely looks a bi
  #17
lillberg's Avatar
Eric Lillberg
Hi Wayne,
Surely looks a bit strange! Could just be a fault in the setup!? What about your makeMesh config, are the faceZones set up properly in the parallel case?
I've run dozens of impellers like yours using the MRF and also comparing with sliding mesh simulations (in general < 5% difference in total flowrate) and also tabulated values (generally < 15% difference on coarse meshes).
Two things about your simulations tells me you'll end up in trouble sooner or later and therefor should be fixed. Firstly, change the location and/or type of your outflow BC. Secondly, if things don't work in serial runs don't bother doing them in parallel. If your case is too big use a coarser mesh to start with.
Also, try the pressure solver settings Dragos showed above. Additionally, run the case with upwind defferencing only for all variables and add "Interpolate(U) upwind phi;" to your interpolation settings in fvSchemes.
Good luck,
/Eric
Old   April 11, 2008, 03:12
Default Hi Eric would you mind to se
  #18
wayne.zhang
Hi Eric
would you mind to send one of your setting(such as makemesh/fvSolution/fcScheme/MRFZones/dynamicMeshDict/Boudary/0 dictionary )or me ?
thanks!
wayne
Old   April 11, 2008, 03:41
Default Sure, Send your e-mail adr
  #19
lillberg's Avatar
Eric Lillberg
Sure,
Send your e-mail adress to eric.lillberg@afconsult.com
/E
Old   April 11, 2008, 04:01
Default Hi My email adress is wayne
  #20
wayne.zhang
Hi
My email adress is waynezw0618@163.com i have sent a email to you.if it was too large for you to send me.please send the setting files(such as makemesh/fvSolution/fcScheme/MRFZones/dynamicMeshDict/Boudary/0 dictionary or other)to me!
thanks!
wayne
Equations in the MRFsimpleFOAM waynezw0618 OpenFOAM Running, Solving & CFD 5 May 7, 2015 05:43
Convergence with MRFSimpleFoam grugg OpenFOAM Running, Solving & CFD 7 March 28, 2014 05:56
MRFSimpleFoam xdanielx OpenFOAM Running, Solving & CFD 0 December 17, 2008 02:28
Strange Velocity JoeSa CFX 1 September 28, 2006 10:13
Strange oscillating velocity zonexo Main CFD Forum 2 April 6, 2006 12:38
