Problems with finding normalized mean wind speed
Dear all,
I just got some problems when writing codes for an application to generate the normalized mean wind speed...the following are the codes: #include "fvCFD.H" #include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H" #include "incompressible/RASModel/RASModel.H" int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createMesh.H" # include "createFields.H" for (runTime++; !runTime.end(); runTime++) { volScalarField Unorm=(1/9.9)*mag(U); Unorm.write(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; Info<< "End\n" << endl; } return(0); } .................................................. .................................................. ........................ The above are the codes.....when I tried to execute this application, I got the following error: "Reading field U Cannot open file" I wonder if there's anything wrong with my codes?? Thanks!! Alice |
Hi Alice,
The error message says the solver cannot open file U. Do you have a case set up with a file 0/U? |
Dear gwierink,
Yes I do have the file 0/U, but I don't know why I still can't run the application...:( Regards, Alice |
Dear Alice,
Are you modifying a solver? Is the code you posted above all code you're compiling and running? Because if it is all code, you're seemingly not solving any equations for U (or p), just calculating Unorm for one time step ... Can you insert your part of the code (the part about Unorm) into an existing solver, save it under a different name, compile it, and see if it runs? |
funkySetFields
How about funkySetFields? i.e. something like (untested):
funkySetFields -create -field Unorm -time 0 -expression 'mag(U)/9.9' Code:
OpenFOAM\OpenFOAM-1.6.x\applications\utilities\postProcessing\velocityField\vorticity\vorticity.C |
Dear gwierink and Mike,
Thanks for your help! I want to ask one more question: is there a utility called "magU" in OpenFOAM-1.5 ? Regards, Alice |
Hi Alice,
I would use mag(U) to get the magnitude of U. But of course you could write something like volScalarField magU = mag(U), to use magU in an equation for better readability. |
Dear gwierink,
Thanks for your advice:) Alice |
