-   -   Cantera: Help me understand this error (http://www.cfd-online.com/Forums/openfoam-solving/71537-cantera-help-me-understand-error.html)
aat January 6, 2010 15:21
Hello everyone:
I am trying to model a reacting flow problem in OpenFOAM 1.5-dev using the alternateSteadyReactingFoam solver. This is a very simple 3D setup, co-flow fuel and air jets in a cylinder, similar to the Sandia flame D geometry. I used the same reaction mechanism and the species BCs as used in the dualInlet example. (I was able to run the sample dualInlet test cases for steady and unsteady configurations just fine)
I attempted to run my problem for 100 timesteps, and at the 99th timestep, the solution aborted with the message:
terminate called after throwing an instance of 'Cantera::CanteraError'
what(): std::exception
Aborted
I am not sure where to look for the problem. Could anyone suggest where to start? Thanks!!
If it helps, the log output from the prior two iterations is included, to show the residuals and solution errors upto this point:
---------append log output from timesteps 98 and 99--------
Time = 98
Solving chemistry
Characteristic time of chemistry: 0.1
smoothSolver: Solving for Ux, Initial residual = 0.269379, Final residual = 0.00513338, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0945435, Final residual = 0.00306857, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.143678, Final residual = 0.00382205, No Iterations 4
PBiCG: Solving for C, Initial residual = 0.000566587, Final residual = 1.60321e-05, No Iterations 2
PBiCG: Solving for CO2, Initial residual = 0.00448204, Final residual = 9.34077e-05, No Iterations 1
PBiCG: Solving for O2, Initial residual = 0.000416701, Final residual = 1.09867e-05, No Iterations 1
Max summe Yi = max((0*C)) [0 0 0 0 0 0 0] 0.15 Min summe Yi = min((0*C)) [0 0 0 0 0 0 0] 0
Fixed kappa in 0 cells due to large deltaY
PBiCG: Solving for h, Initial residual = 0.0014209, Final residual = 8.11273e-05, No Iterations 1
--> FOAM Warning :
From function canteraChemistryModel::calcDQ(volScalarField &dQ)
in file canteraChemistryModel.C at line 321
Calculation of dQ is not yet verified
GAMG: Solving for p, Initial residual = 0.301642, Final residual = 0.0105844, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0109159, Final residual = 0.000542107, No Iterations 4
time step continuity errors : sum local = 0.396288, global = 0.0817594, cumulative = 0.645363
bounding p, min: 94456.6 max: 110249 average: 100011
rho max/min : 76.6465 0.983823
smoothSolver: Solving for epsilon, Initial residual = 0.06717, Final residual = 0.00570385, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.0244528, Final residual = 0.000708644, No Iterations 4
ExecutionTime = 509.54 s ClockTime = 516 s
Time = 99
Solving chemistry
smoothSolver: Solving for Ux, Initial residual = 0.0881626, Final residual = 0.00316143, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.0794196, Final residual = 0.0028376, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.105029, Final residual = 0.00352823, No Iterations 4
PBiCG: Solving for C, Initial residual = 0.000613862, Final residual = 1.63715e-05, No Iterations 2
PBiCG: Solving for CO2, Initial residual = 0.00455755, Final residual = 9.60917e-05, No Iterations 1
PBiCG: Solving for O2, Initial residual = 0.000422945, Final residual = 1.17823e-05, No Iterations 1
PBiCG: Solving for h, Initial residual = 0.000893174, Final residual = 3.83304e-05, No Iterations 1
Aborted
-----------------end append------------------
-AAT
gschaider January 11, 2010 07:45
Originally Posted by aat (Post 241669)
Hello everyone:
Time = 98
Solving chemistry
--> FOAM Warning :
Time = 99
Solving chemistry
Aborted
The time of the exception (after the calculation of the enthalpy) indicates that it occurs during thermo-correct(). Usually there should be a bit more output in the stack-trace (try setting FOAM_ABORT). Anyway. The density range in the previous time-step seems awfully wide to me (two orders of magnitude). Is this legal? Try smaller relaxation parameters
Bernhard
markusrehm January 12, 2010 08:35
you are facing a common problem in steady-state chemistry solution. The solution diverges at start-up. When I run a simulation like that I do the following
  • I run a few hundred steps without chemistry to converge the flow field (switch off turbulentReaction in constant/chemistryProperties) - sometimes I also have to run adiabatic (without hEqn) or "hot adiabatic" and switch on hEqn later
  • set the temperature to something like 2000K in a square where fuel and oxidizer are mixed (setFields)
  • activate chemistry and use very small under relaxation factors at the beginning
  • you could also try to ramp up the fuel fraction in the jet from zero to full
There is no general way to get a case running you have to play around with different combinations of the tools just mentioned. Maybe you can post the residuals here.
Regards, Markus.
