Home > Forums > OpenFOAM Running, Solving & CFD
OpenFoam parallel scalability
Like Tree1Likes
Old   January 13, 2010, 18:25
Patricio Bohorquez
pbohorquez is on a distinguished road
First, the computational time for each time step is mainly spent on solving for the pressure equation in almost all our simulations. This is the most expensive operation performed at every time step. Therefore, i feel that its speed up fixes the scaling of the global simulation.
Try the parallel simulation with the same value of nCorrectors as for the serial. Check if the number of iterations for the pressure in the serial and parallel case is the same at each time step. If this was so, then you could plot the speed-up curve with confidence.
Finally, 0.0026 seconds is more than enough. I ussually run just 3 time steps and consider the ClockTime equal to that employed in the 2º time step. So you avoid including IO operation time.
pbohorquez is offline   Reply With Quote
Old   January 14, 2010, 03:36
Steve Colde
hpc_benchmark is on a distinguished road
I am still doubt about the speed up.
current setting 1000x1000, delta 0.00005, decomposition (16 8 1) for 128 cores.
Use simple method. fvSolution nCorrectors=10.
On this 128 cores setting, IB should show big difference as others did, but i can't achieve big difference as your paper stated. I believe it is test case setting issue.
BTW, what is the endtime you set?
hpc_benchmark is offline   Reply With Quote
Old   January 14, 2010, 07:32
Patricio Bohorquez
Are you using a shared or distributed memory machine?
I think that I have reported successful results for HP Superdome Itanium II (<= 32 cores) by using Jasak's case:
DROPLET SPLASH SCALING TEST. This scaling test is set up to help with the validation of parallel performance of OpenFOAM... (see README file)
Hrv's results, up to 4 cores, are reported in "Preconditioned Linear Solvers for Large Eddy Simulation" (Jasak, 2007).
On the other hand, I was unable to get a speed-up greater than 16 for the 3D cavity by using 8 quad-cores AMD Opteron 8382 with shared memory (TYAN S4985G3NR-E Thunder n4250QE; 64 GB RAM) and 4M cells (I did not check Jasak's case for the following reason). Indeed, I have run a very simple simulation with a smaller mesh (100K) to isolate the cause of the problem: decompose the case in 4 domains (2 2 1) and run the simulation in the same quad-core (you can select the socket by setting "numactl --cpubind=... --membind=... script.sh" where "script.sh" contains "mpirun -np 4 -hostfile host-dell icoFoam -case cavity -parallel"); subsequently, run the same simulation without cpu affinity; as far as i understood, your nodes have 2 quad-cores, so in the latter case you must corroborate that 2 threads are running in each quad. Do you get the same ClockTime for the simulation?
Old   January 14, 2010, 21:17
Steve Colde
they are standard rack servers. 2CPUs/4 cores each CPU.
I have both infiniband and gige.
When I run openfoam over infiniband, there are always big traffic generated by Openfoam over gige meanwhile, even more than over IB. This prevented infinband from getting good performance.
Why does OpenFoam work like this? how can i make OF run over IB only?
Old   January 15, 2010, 05:29
Patricio Bohorquez
The communication libraries are given by $WM_MPLIB. Its value is set in OpenFOAM/OpenFOAM-1.6.x/etc/bashrc and can be tuned in OpenFOAM/OpenFOAM-1.6.x/etc/settings.sh
Old   October 27, 2012, 08:21
Ozgur Kirlangic
ozgur is on a distinguished road
Hello friends,
About the scaling tests I have got a question.. I hope someone gives me a hint.
I made a simple test using icoFoam on the cavity tutorial:
1) serial
2) parallel with 2 procs
3) parallel with 4 procs.
The problem is: In the outputs, the number of iterations reported are not same in the three of the test cases. In a large scale problem with a long simulation duration this difference in the iteration counts may(??) lead to a large number of difference in the total executed floating point operations/per core and it may be difficult to compare results of different decomposions in scaling study.
The question is: Is this a bug or is there any way to fix the number of iterations while keeping the same level of accuracy?
Ozgur
Serial Iterations:
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.96338e-06, No Iterations 8
DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 7.55402e-07, No Iterations 35
DICPCG: Solving for p, Initial residual = 0.523591, Final residual = 9.72352e-07, No Iterations 34
DILUPBiCG: Solving for Ux, Initial residual = 0.148584, Final residual = 7.15711e-06, No Iterations 6
DILUPBiCG: Solving for Uy, Initial residual = 0.256618, Final residual = 8.94127e-06, No Iterations 6
DICPCG: Solving for p, Initial residual = 0.379232, Final residual = 3.38648e-07, No Iterations 34
DICPCG: Solving for p, Initial residual = 0.286937, Final residual = 5.99637e-07, No Iterations 33
DILUPBiCG: Solving for Ux, Initial residual = 0.0448669, Final residual = 2.39894e-06, No Iterations 6
DILUPBiCG: Solving for Uy, Initial residual = 0.0782408, Final residual = 1.45948e-06, No Iterations 7
DICPCG: Solving for p, Initial residual = 0.109591, Final residual = 5.81093e-07, No Iterations 32
Parallel Iterations (two procs):
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 4.73711e-06, No Iterations 10
DICPCG: Solving for p, Initial residual = 1, Final residual = 5.66841e-07, No Iterations 40
DICPCG: Solving for p, Initial residual = 0.523592, Final residual = 8.51439e-07, No Iterations 39
DILUPBiCG: Solving for Ux, Initial residual = 0.148584, Final residual = 6.18044e-06, No Iterations 8
DILUPBiCG: Solving for Uy, Initial residual = 0.256618, Final residual = 5.05961e-06, No Iterations 8
DICPCG: Solving for p, Initial residual = 0.379233, Final residual = 4.79055e-07, No Iterations 39
DICPCG: Solving for p, Initial residual = 0.286932, Final residual = 8.27536e-07, No Iterations 38
DILUPBiCG: Solving for Ux, Initial residual = 0.0448669, Final residual = 2.78802e-06, No Iterations 8
DILUPBiCG: Solving for Uy, Initial residual = 0.078239, Final residual = 5.2207e-06, No Iterations 7
DICPCG: Solving for p, Initial residual = 0.109579, Final residual = 7.5002e-07, No Iterations 37
Parallel Iterations (four procs):
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 8.58781e-06, No Iterations 10
DICPCG: Solving for p, Initial residual = 1, Final residual = 6.80001e-07, No Iterations 42
DICPCG: Solving for p, Initial residual = 0.523592, Final residual = 7.57882e-07, No Iterations 41
DILUPBiCG: Solving for Ux, Initial residual = 0.148584, Final residual = 5.92338e-06, No Iterations 9
DILUPBiCG: Solving for Uy, Initial residual = 0.256618, Final residual = 2.9563e-06, No Iterations 10
DICPCG: Solving for p, Initial residual = 0.379253, Final residual = 6.35855e-07, No Iterations 41
DICPCG: Solving for p, Initial residual = 0.28695, Final residual = 3.74664e-07, No Iterations 41
DILUPBiCG: Solving for Ux, Initial residual = 0.0448671, Final residual = 9.45275e-06, No Iterations 8
DILUPBiCG: Solving for Uy, Initial residual = 0.0782388, Final residual = 9.94066e-06, No Iterations 8
DICPCG: Solving for p, Initial residual = 0.109576, Final residual = 4.91478e-07, No Iterations 40
ozgur is offline   Reply With Quote
Old   October 30, 2012, 06:29
Zoltan Hernadi
zhernadi is on a distinguished road
Dear Ozgur,
You may find answers here:
Parallel running needs more iterations?
Zoltan
zhernadi is offline   Reply With Quote
Thread Tools
Trackbacks are On
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 23 June 22, 2016 08:34
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Testing OpenFOAM parallel computing jason.ryon OpenFOAM 0 October 5, 2009 11:46
Parallel solution in OpenFOAM makaveli_lcf OpenFOAM Running, Solving & CFD 0 September 21, 2009 08:07
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
