For cyclicGgi boundary pressure is not solved !
Old   January 13, 2010, 08:42
Default For cyclicGgi boundary pressure is not solved !
Mahendra
mahendra is on a distinguished road
Dear Foamers
I am having an annulus mesh with 90 degree sector. The faces on the sector are defined as cyclicGgi and bottom is specified as inlet with some velocity and the top as outlet with zero pressure.
when I am running simpleFoam, it solves for Ux, Uy and Uz for one iteration and when it comes for pressure, it is exiting the simpleFoam application.
Please can anyone help me with this.
This is my boundary file:
6
per2
type cyclicGgi;
nFaces 1000;
startFace 34160;
shadowPatch per1;
zone right;
separationOffset (0 0 0);
rotationAxis (0 0 1);
rotationAngle 90; // Degrees
bridgeOverlap off;
per1
type cyclicGgi;
nFaces 1000;
startFace 35160;
shadowPatch per2;
zone left;
rotationAngle 0; // Degrees
bridgeOverlap off;
bottom
type wall;
nFaces 240;
startFace 36160;
top
type wall;
nFaces 240;
startFace 36400;
wall
type wall;
nFaces 600;
startFace 36640;
shaft
type wall;
nFaces 600;
startFace 37240;
U file:
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 0.0 0.0 0.0 );
boundaryField
per2
type cyclicGgi;
value uniform (0 0 0);
per1
type cyclicGgi;
bottom
type fixedValue;
value uniform (0 0 0.01);
top
type zeroGradient; //fixedValue;
//value uniform (0 0 0);
wall
type fixedValue;
shaft
type fixedValue;//rotatingWallVelocity;
// origin (0 0 0);
// axis (0 0 1);
// omega 10;
p file:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.0;
boundaryField
per2
type cyclicGgi;
value uniform 0;
per1
type cyclicGgi;
value uniform 0;
bottom
type zeroGradient;
top
type fixedValue;
value uniform 0;
wall
type zeroGradient;
shaft
type zeroGradient;
and this is the output in the console
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model laminar
Starting time loop
Creating ggi check
Time = 201
smoothSolver: Solving for Ux, Initial residual = 0.20210891, Final residual = 0.0001459087 1, No Iterations 11
smoothSolver: Solving for Uy, Initial residual = 0.2028729, Final residual = 0.00014988579 , No Iterations 11
smoothSolver: Solving for Uz, Initial residual = 4.9124799e-08, Final residual = 4.9124799 e-08, No Iterations 1
openfoam-1.5-dev@Clust7:
Thanks
Mahendra.
mahendra is offline   Reply With Quote
Old   January 14, 2010, 05:40
Hrvoje Jasak
hjasak will become famous soon enough
Doh!
per2: rotation angle = 90;
per1: rotation angle = 0;
See the problem? Please switch on some GGI debugging, which will produce a VTK file of the original and transformed cyclic GGI surface and then look at it in paraview: they should be on top of each other.
Also, there is a check in the source code which says:
if
(mag(rotationAngle()) - mag(cyclicShadow().rotationAngle())) > SMALL
|| cmptSum(rotationAxis() - cyclicShadow().rotationAxis()) > SMALL
FatalErrorIn("void cyclicGgiPolyPatch::check() const")
Therefore, your case with the boundary file you listed above WILL fail.
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   January 18, 2010, 03:50
Mahendra
Hello Sir,
My case started working after looking into the code and changing the rotation angle in the boundary file.
per2: -90
per1: 90
Thanks and Regards
Mahendra
Old   March 16, 2010, 04:05
Herman
enry is on a distinguished road
Hi prof Hrvoje Jasak,
first of all Thank you for the 1.5-dev development.
Sorry if I write here but I need to ask you a simple question: Can I use RealizableKE model for turbulent simulation involving Ggi?
I know from FLUENT manual that :
"One limitation of the realizable k- model is that it produces non-physical turbulent
viscosities in situations when the computational domain contains both rotating and sta-
tionary fluid zones
[...] In FLUENT, the term −2 ijk ωk is, by default, not included in the calculation of Ωij . This is an extra rotation term that is not compatible with cases involving sliding meshes or multiple reference frames."
So I understand that in FLUENT I can use RealizableKe model without any problems, even if I use sliding interface, because the extra rotation term is not included by default in calculation.
What about OF 1.5-dev?
Thanks in advance.
Regards.
Enry.
enry is offline   Reply With Quote
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Boundary Condition pressure inlet/oulet for combustion simulations Giuki FLUENT 0 May 6, 2009 10:04
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
