Problems with finding normalized mean wind speed
Old   December 26, 2009, 12:22
Default Problems with finding normalized mean wind speed
Alice
Alicelin is on a distinguished road
Dear all,
I just got some problems when writing codes for an application to generate the normalized mean wind speed...the following are the codes:
#include "fvCFD.H"
#include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H"
#include "incompressible/RASModel/RASModel.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
for (runTime++; !runTime.end(); runTime++)
volScalarField Unorm=(1/9.9)*mag(U);
Unorm.write();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return(0);
The above are the codes.....when I tried to execute this application, I got the following error:
"Reading field U
Cannot open file"
I wonder if there's anything wrong with my codes??
Thanks!!
Alice
Alicelin is offline   Reply With Quote
Old   December 28, 2009, 03:14
Gijsbert Wierink
gwierink is on a distinguished road
Hi Alice,
The error message says the solver cannot open file U. Do you have a case set up with a file 0/U?
Regards, Gijs
gwierink is offline   Reply With Quote
Old   December 28, 2009, 21:20
Alice
Dear gwierink,
Yes I do have the file 0/U, but I don't know why I still can't run the application...
Regards,
Alice
Old   December 29, 2009, 03:47
Gijsbert Wierink
Dear Alice,
Are you modifying a solver? Is the code you posted above all code you're compiling and running? Because if it is all code, you're seemingly not solving any equations for U (or p), just calculating Unorm for one time step ...
Can you insert your part of the code (the part about Unorm) into an existing solver, save it under a different name, compile it, and see if it runs?
Regards, Gijs
Old   December 29, 2009, 07:09
Default funkySetFields
Michael Roth
roth is on a distinguished road
How about funkySetFields? i.e. something like (untested):
funkySetFields -create -field Unorm -time 0 -expression 'mag(U)/9.9'
Otherwise, if you want to go the roll-your-own route, try modifying a working utility that operates on U e.g. "vorticity", code found in
OpenFOAM\OpenFOAM-1.6.x\applications\utilities\postProcessing\velocityField\vorticity\vorticity.C
Mike
roth is offline   Reply With Quote
Old   January 8, 2010, 02:09
Alice
Dear gwierink and Mike,
Thanks for your help! I want to ask one more question: is there a utility called "magU" in OpenFOAM-1.5 ?
Regards,
Alice
Old   January 8, 2010, 03:07
Gijsbert Wierink
Hi Alice,
I would use mag(U) to get the magnitude of U. But of course you could write something like volScalarField magU = mag(U), to use magU in an equation for better readability.
Regards, Gijs
Old   January 18, 2010, 03:51
Alice
Dear gwierink,
Thanks for your advice
Alice
How to find RPM from wind speed in Floworks? Matco FloEFD, FloWorks & FloTHERM 21 March 22, 2010 15:18
Wind Tunnel Testing Francesco Nicolosi Main CFD Forum 0 November 25, 2008 12:55
problems in high speed external flow jon william FLUENT 2 January 14, 2007 06:37
High speed flow problems Sawa FLUENT 3 January 14, 2003 01:10
Atmospheric Wind Profile - Inlet Subroutine Roger Siemens 3 December 12, 2002 10:00
