-   -   interFoam (and other multiphase solvers): What is solved? (http://www.cfd-online.com/Forums/openfoam-solving/71991-interfoam-other-multiphase-solvers-what-solved.html)
mconroy January 21, 2010 15:18
Does interFoam solve 2 continuity equations and 2 momentum equations?
If so, are these continuity and momentum equations solved for (1) the phase specified by alpha1 and for (2) the mixture of both phases?
Also, for n phases, does multiphaseInterFoam solve n continuity equations and n momentum equations?
(I assume that I will eventually be able to figure this out by myself from the source code when I have a better understanding of C++, but for now, I need help... :o)
Thanks!
Mike
kwardle February 18, 2010 19:50
No. Both formulations (two phase and n-phase) solve a single set of momentum equations NOT one per phase. A true multiphase formulation would be useful, but as yet there isn't one that combines with VOF interface modeling in OF. (AFAIK anyway...)
kathrin_kissling February 19, 2010 06:05
Hi mconroy,
there are some really good hints about how interFoam and twoPhaseEulerFoam is implemented in
http://powerlab.fsb.hr/ped/kturbo/Op...chePhD2002.pdf
Best
Kathrin
mconroy February 23, 2010 17:07
Thanks, Kent and Kathrin. I appreciate your help!
