Difficulty running an inviscid compressible nozzle flow using OpenFOAM |
February 7, 2010, 16:32 |
Radoslav Bozinoski
Hi Foamers,
I am very new to OpenFOAM and have only been playing around with it for about a month(very unsuccessfully I might add). I have heard great things about this cfd toolkit and wanted to start getting my feet wet with some of its capabilities. I've gone through some of the tutorials and have read a lot of journal articles where OpenFOAM was used and am convinced that OpenFOAM will be a great tool for my future research aspirations. Unfortunately, my first few attempts at using it for cases other than what's packaged with the tutorials have not gone very well. So what I finally did was focus all my efforts on learning OpenFOAM by first using the following Fluent tutorial. http://courses.cit.cornell.edu/fluent/nozzle/step4.htm This tutorial outlines a simple inviscid nozzle flow problem and I wanted to reproduce the results using OpenFOAM. I converted the mesh using 'fluentMeshToFoam' and then tried to first generate an initial flow field using potentialFoam and then launch an inviscid case using rhoSonicFoam. I was unsuccessful with both. I've attached a tarball of my case files and was hoping someone could help me understand what I am doing wrong and how to properly launch this case. I will admit that I don't have a clear understanding of how to properly implement the boundary conditions or how to get more information regarding the current capabilities in OpenFOAM. Once again, thank you all in advance and any assistance would be greatly appreciated. Last edited by rbozinoski; February 8, 2010 at 00:31. |
February 10, 2010, 09:20 |
Radoslav Bozinoski
Can anyone please offer any advice or help. Still very much lost with OpenFOAM.
Thank you in advance. |
February 11, 2010, 10:36 |
Hi Radoslav
What is the problem? you need to be more specific. I have seen your case (rhoSonicFoam) and you make some mistakes. In the /0/p the internalField of pressure must be the value that you specify at the outlet. Try also to lower your deltaT. Best luck Cheers, CX |
February 12, 2010, 00:08 |
Radoslav Bozinoski
Hello Carlos,
Thank you so much for replying. I took your advice and set the internal pressure field to the exit pressure and lowered my time step but I still get the following error: ********************** Create time Create mesh for time = 0 Reading thermodynamicProperties Reading field p Reading field T Reading field U Starting time loop Time = 1e-06 Max Courant Number = 0.00504052 request for surfaceScalarField phi from objectRegistry region0 failed available objects of type surfaceScalarField are 4 ( phiv limitedLinearLimiter(rho) differenceFactors_ weightingFactors ) #0 Foam::error:rintStack(Foam::Ostream&) in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoSonicFoam" #3 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvsPatchField, Foam::surfaceMesh> >(Foam::word const&) const in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::totalPressureFvPatchScalarField::updateCoeff s(Foam::Field<Foam::Vector<double> > const&) in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #6 Foam::fv::gaussConvectionScheme<double>::fvmDiv(Fo am::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) const in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoSonicFoam" #8 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoSonicFoam" #9 main in "/home/rbozinoski/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoSonicFoam" #10 __libc_start_main in "/lib/libc.so.6" #11 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 From function objectRegistry::lookupObject<Type>(const word&) const in file /home/rbozinoski/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140. FOAM aborting Aborted ****************************** I tracked down the problem to the total pressure/temperature boundary conditions. It seems to be complaining about the variable phi. I have tried using other bc at the inlet but all eventually diverge. I was wondering if you are having the same issues. Also, I am not sure if my control/thermodynamicProperties file is correct. I am simply trying to run this case inviscid and compressible. I have attached my latest rhoSonic files. You will have to use the fluentMeshToFoam utility to generate the OpenFOAM mesh to run the simulation. Any further advice will be greatly appreciated. Thank you again for your help. |
February 12, 2010, 05:22 |
I never used a density based solver in OpenFoam, just a Pressured based.
If you want to try with the rhoPisoFoam check the boundary conditions in this post (the 0 file). http://www.cfd-online.com/Forums/ope...tml#post244986 Another thing it seems that you have a pressure realation very high resulting in Ma=2.9, in the other and the the velocity (internalField and intial value) is to low 30 m/s. This is why it crashes (imagine you crashing against a wall). My advice is to increase the velocity in the internal field and at the inlet to 2.9 Ma. Good Luck CX |
February 12, 2010, 10:55 |
Radoslav Bozinoski
Carlos,
Yeah I think you are correct regarding the velocity initialization. I'll have to give that a try to see what happens. However, I am pretty sure that I will still get the same error I posted earlier regarding the total pressure and temperature bc's. Thanks for pointing me to your other post. I think I will switch to the rhoPisoFoam solver and try and reproduce that subsonice case first and then the transonic case. I noticed that you posted your initialization files and was wondering if you would mind also posting the grid and any other files I would need to run this simulation. I just wanted to start from a working case and then build up to a transonic from there. Thank you again for your help, -RB |
February 12, 2010, 11:24 |
My email is carlos_xisto@hotmail.com
Just send me a request and I will mail the files to you Cheers CX |
January 14, 2013, 02:16 |
Baris (Heewa)
Dear Carlos,
Hi, I am new user in openFoam I try to run the cavitatingFoam for the throttle. For pressure at the inlet BC set as totalPressure so by changing the velocity i try to get new results but give following errors. COuld you help to me what does it mean and how can i correct it? Thanks. Phase-change corrected p max-min : 6.37897e+07 400 max(U) 14881.4 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/cavitatingFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/cavitatingFoam" Floating point exception (core dumped) |
April 5, 2014, 04:13 |
Rocket Nozzle flow simulation in OpenFOAM
Ranjan
Rep Power: 12 |
Dear Foamers
Can anyone suggest a solver I can use for simulating supersonic flow in a rocket nozzle? Thanks |
April 5, 2014, 12:29 |
rhoCentralFoam is OK
#10 | |
何刚
you need to specify all variables except one at inlet (f.g. fixed values for temperature (static), and extrapolate all variables from outlet (zero gradient). You can use totalPressure, total temperature, zeroGradient(U) for inlet of the nozzle, and specify static pressure and temperature. |
November 17, 2015, 00:53 |
#11 | |
Daniel Alejandro
have you sucessed with the nozzle simulation?, I am new in openfoam, and I m trying to do the same simulation but using "sonicFoam" instead of "rhoSonic", could you please share the 0 folder of your simulation?, I would appreciate that very much, thank you in advance |
December 29, 2015, 07:19 |
I am trying to simulate exactly the same case.
#12 | |
Nick Zang
I am trying to perform exactly the same simulation as you mentioned from the Cornell course in OpenFOAM. Really appreciate if you can share some experiences on the case! Thanks. |
compressible, invicid, nozzle flow, openfoam |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Compressible Nozzle Flow | sebastian | OpenFOAM Running, Solving & CFD | 14 | September 21, 2016 10:47 |
3D Compressible Nozzle Flow Convergence Problem | mep10jl | FLUENT | 2 | July 30, 2013 17:09 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 06:12 |
Axisymmetirc Compressible Flow in a C/c and Nozzle | Nauman | FLUENT | 0 | December 21, 2004 07:40 |
