Initial condition
Old   February 15, 2010, 04:57
Exclamation Initial condition
s&m
s&m is on a distinguished road
Hi to everyone!
I would like to create a turbulent initial condition for my channel flow simulation.. but i don't know how to do it! I used foamCalc randomise 0.2 U for creating a perturbation inside the velocity field.. but after few time-steps (10= 1 sec), the flow became laminar again.. So i try to perturb the flow every 10 time step.. but now i'm at 20 sec and if i don't perturb the flow, it returns laminar again (after 30 time steps= 3 second)... what i have to do?
thx
s&m is offline   Reply With Quote
Old   February 15, 2010, 12:54
Alberto Passalacqua
You probably want perturbU for the channel...
http://www.cfd-online.com/Forums/ope...-perturbu.html
Alberto Passalacqua
Old   June 23, 2011, 18:24
Tarak
Tarak is on a distinguished road
Hii Alberto,
Can you please let me know the best way to get an initial perturbed field for starting a LES simulation? Just like perturbU, which is for channel flow, I need to know a generalized way to get the preturbations. Presently I am using the turbulentinlet boundary condition, with 2% fluctuation. Is it a good way to generate instabilities?
Thanks,
Tarak
Tarak is offline   Reply With Quote
Old   June 23, 2011, 18:41
Alberto Passalacqua
Originally Posted by Tarak View Post
Hii Alberto,
No, turbulentInlet basically adds noise, so it's not really a good way to initialise turbulence.
The initialisation depends on the case you are considering. If you have an inlet, and have detailed information on the flow conditions there, you might want to consider synthetic turbulence BC's (you'll have to implement them). If you are interested, you should check the literature on the topic. Some OF users were working on that too, so the Turbulence SIG (see wiki) might be of help.
Best,
Alberto Passalacqua
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
