Solving problem on subdomain
Old   March 31, 2011, 10:38
Default Solving problem on subdomain
Andreas P
andreasp is on a distinguished road
Hi everyone!
I want to compute an incompressible flow profile round a sphere in a box (see attached PNG).
The mesh is generated with ICEM, stored in Fluent format, and converted to OF with fluent3DMeshToFoam without any problems. Most important converter output:
FINISHED LEXING
Creating patch 0 for zone: 12 name: SURFS type: wall
Creating patch 1 for zone: 13 name: SPHERE type: wall
Creating cellZone 0 name: CREATED_MATERIAL_6 type: fluid
Creating cellZone 1 name: CREATED_MATERIAL_7 type: fluid
Creating faceZone 0 name: int_CREATED_MATERIAL_6 type: interior
Creating faceZone 1 name: int_CREATED_MATERIAL_7 type: interior
faceZone from Fluent indices: 0 to: 7430 type: interior
faceZone from Fluent indices: 7431 to: 7757 type: interior
patch 0 from Fluent indices: 7758 to: 8317 type: wall
patch 1 from Fluent indices: 8318 to: 8407 type: wall
Since other people in our group use the same mesh also for computing mass transport inside the sphere, it is also meshed. However, I am only interested in the flow profile *around* the sphere, i.e. its surface == impermeable walls.
I have not yet tried to run a simulation (with simpleFoam), but I have a few general questions in advance:
How does OF treat such multidomain problems in general? Will it treat the two cellZones as one, or will it just ignore the second, or what else?
Or how can I tell OF to ignore the cells inside inside the sphere?
I'd appreciate any information on that!
Andreas
andreasp is offline   Reply With Quote
Old   April 1, 2011, 02:53
Alberto Passalacqua
I would remove the cells inside the sphere. You can do this defining a cellSet and deleting the elements belonging to it. Take a look at cellSet/setSet tools.
Alberto Passalacqua
Old   April 1, 2011, 04:44
Andreas P
Alberto,
thanks for your reply.
After fixing the boundary conditions at inlet and outlet, I now got simpleFoam to compute a solution. It works, but the solver includes the cells inside the sphere. Since these are completely surrounded by walls, nothing happens there. But I should definitely get rid of the cells for larger realistic problems...
I did some googling on cellSet and setSet, but didn't really come up with useful documentation. Am I missing any important docu site? Or maybe could anyone shed some light on how to use these tools?
Thanks again!
Andreas
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 02:18
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
