Unexpected results from interFoam
Old   February 23, 2010, 16:39
Default Unexpected results from interFoam
mconroy is on a distinguished road
I am running the interFoam solver to do what I hoped would be a simple mulitphase simulation: filling a one-dimensional column with a mixture of water and air (without gravity).
When I run the simulation with the input liquid volume fraction equal to one, I get results that I expect (see filling tube plot).
However, when I changed the volume fraction to 0.75, I get weird oscillations in the liquid volume fraction as a function of height (see weird plot). I have tried changing the cell size and time steps, but I still had similar problems.
Boundary conditions:
Top of column (RHS in plots):
pressure = 1 atm
velocity -> zeroGradient
liquid volume fraction -> zeroGradient
Bottom of column (LHS in plots):
pressure -> zeroGradient
velocity = 10 cm/s
liquid volume fraction = {1 seems to work fine, <1 does not}
Initial conditions:
pressure = 1 atm
velocity = zero
liquid volume fraction = 0
I would like to understand what I am doing wrong and to hopefully get some help on how to get it right. Please let me know if any more information is needed.
Thanks,
Mike
mconroy is offline   Reply With Quote
Old   March 30, 2011, 22:31
Dave West
Terp is on a distinguished road
Mike -
I'm no expert on VOF methods, but my understanding is that it is looking for the interface between 2 fluids that don't mix. If you put in a fluid that is a uniform 75% phase 1 (and 25% phase 2), they are mixed to the sub-grid scale, and the code can't find a surface to separate them on. I wouldn't expect a good answer. If you bring in some of each phase, at 100% and 0%, separated to the scale of the mesh, I expect you would see better results.
Terp
Terp is offline   Reply With Quote
Old   March 31, 2011, 11:05
Terp,
Thanks for the reply. I need to understand the tools before I know what I can do with them
Mike
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
Are the VOF results of interFoam grid independent asaha OpenFOAM Running, Solving & CFD 1 June 26, 2009 04:27
[OpenFOAM] Is that a circle Results from interFoam sega ParaView 2 May 8, 2008 02:49
Strange results from interFoam solution converges but sum of all forces not equal to zero nicasch OpenFOAM Running, Solving & CFD 0 April 15, 2008 02:01
unexpected results Kevin Rogers Main CFD Forum 7 October 6, 2005 11:34
