Convective boundary condition
Old   September 22, 2008, 09:34
Default Dear OF community, I'm tryi
Andrea M.A. Barbera
andrea_barbera is on a distinguished road
Dear OF community,
I'm trying to implement a convective boundary condition in OF. Essentially this condition should be applied in a solid domain and should guarantee the coherence of thermal fluxes at the interface between the solid and a hypotetic fluid. This condition should respect the known equation:
-k*dT/dn = HTC*(T-T_fluid)
Where k, HTC and T_fluid are parameters of the boundary condition (I think to have succesfully loaded them in my BC), and T and dT/dn are respectively the gradient and the value that I must impose.
From which BC should I start to obtain my BC? I tried to start from BC derived from fixedValue, fixedGradient and mixed, but I do not know how to impose a linear combination of two fields like T and dT/dn and where impose it.
I have tried some tricks:
---- Starting from fixedValue-derived BCs I try to discretize the gradient as
(T_to_set - this->patchInternalField())
*this->patch().deltaCoeffs())
getting an equation in "T_to_set", the value that I try to set as BC.
---- Starting from fixedGradient-based BCs I try to discretize T as
(gradient_to_set + *this->patch().deltaCoeffs()) + this->patchInternalField()
getting an equation in "gradient_to_set", the value that I try to set as BC.
Unfortunaley these triks had no results and I get no result, also for some problem related to type mismatch during compiling. I do not know how to start implement this BC starting from mixed-BC or if the trikc that I have followed are reasonable
Can you help me?
Best regards
Andrea
andrea_barbera is offline   Reply With Quote
Old   September 22, 2008, 10:40
Default Hi Andrea, I think you can
Takuya OSHIMA
7islands is on a distinguished road
Hi Andrea,
I think you can have a look at either
1. the mixed-derived advective b.c. in OF 1.5 or
2. [Advertisement] the fixedGradient-derived convectiveOutlet b.c. I posted here on Sep. 05, 2007.
1. is much more sophiscated but may require a bit of patience to read.
Takuya
7islands is offline   Reply With Quote
Old   September 23, 2008, 03:16
Default Hi Takuya, Thanks for your
Andrea M.A. Barbera
Hi Takuya,
Thanks for your advise. I will check these boundary conditions and start from them!
Andrea
Old   September 24, 2009, 06:45
Jitao Liu
awacs is on a distinguished road
Hi Andrea,
I am interested in this convective boundary condition too. Have you finished it?
I am study the heating process of a solid, which has several heating channels for hot gas or hot oil flowing through. So the boundary condition at the channel wall shuold belongs to the third-class, just as you described above:
Please give me some suggestions. Thanks in advance.
Regards,
Jitao
awacs is offline   Reply With Quote
Old   March 4, 2010, 04:36
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
Hi Andrea,
I am also interested in implementing the mixed heat transfer BC. Did you manage to make it?
rgds
Bjorn
bhh is offline   Reply With Quote
convective boundary condition Mani CFX 8 March 21, 2017 09:59
convective boundary condition for outflow BC Pang Shengyong Main CFD Forum 1 August 24, 2007 17:21
Convective Boundary Condition garni FLUENT 0 September 25, 2005 13:00
Convective boundary condition STN Main CFD Forum 5 May 29, 2002 08:47
convective boundary condition frederic felten Main CFD Forum 1 April 25, 2001 01:20
