April 1, 2010, 09:47 |
Parallel Run problem
I have a problem with running firefoam in parallel. Working with serial there is no problem. With parallel, I encountered a problem after writing two or three data set the program stopped and exit and give the following statments:
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/shhe/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/shhe/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ??smoothSolver: Solving for Uz, Initial residual = 0.00703829, Final residual = 5.77079e-09, No Iterations 8 DILUPBiCG: Solving for ft, Initial residual = 0.00165804, Final residual = 4.86177e-10, No Iterations 3 max(ft) = 1 min(ft) = -3.744e-09 in "/lib64/libc.so.6" #3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)max(ftVar) = 0.0341966 min(ftVar) = 1.3266e-128 in "/home/shhe/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const in "/home/shhe/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) constDILUPBiCG: Solving for ft, Initial residual = 0.00185502, Final residual = 9.89006e-10, No Iterations 3 max(ft) = 1 min(ft) = -4.84243e-07 in "/home/shhe/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #6 GAMG: Solving for pd, Initial residual = 0.0173815, Final residual = 6.79687e-09, No Iterations 13 max(ftVar) = 0.0340001 min(ftVar) = 9.06034e-141 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&)time step continuity errors : sum local = 1.79503e-11, global = -8.99262e-13, cumulative = 0.000116242 in "/home/shhe/OpenFOAM/shhe-1.6/applications/bin/linux64GccDPOpt/fireFoam" #7 smoothSolver: Solving for k, Initial residual = 0.00373242, Final residual = 4.77105e-09, No Iterations 6 mainExecutionTime = 1301.07 s ClockTime = 1311 s in "/home/shhe/OpenFOAM/shhe-1.6/applications/bin/linux64GccDPOpt/fireFoam" #8 __libc_start_mainCourant Number mean: 0.0316383 max: 0.505215 deltaT = 0.00146301 Time = 0.185297 in "/lib64/libc.so.6" #9 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) constDILUPBiCG: Solving for ft, Initial residual = 0.00166794, Final residual = 4.49196e-10, No Iterations 3 max(ft) = 1 min(ft) = -5.56997e-09 in "/home/shhe/OpenFOAM/shhe-1.6/applications/bin/linux64GccDPOpt/fireFoam" max(ftVar) = 0.0345528 min(ftVar) = 9.88153e-128 19253 (n1) exited due to signal 8 The following is my controlDict: application fireFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 20.0; deltaT 1e-5; //writeControl adjustableRunTime; writeControl runTime; writeInterval 0.1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; graphFormat raw; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.5; maxDeltaT 0.01; and decomposeParDict: numberOfSubdomains 8; method simple; //method metis; //method scotch; simpleCoeffs { n (2 2 2); delta 0.001; } hierarchicalCoeffs { n (1 1 1); delta 0.001; order xyz; } scotchCoeffs { processorWeights ( 1 1 1 1 1 1 1 1 ); } manualCoeffs { dataFile ""; } distributed no; roots ( "<root0>" "<root1>" "<root2>" "<root3>" "<root4>" "<root5>" "<root6>" "<root7>" ); |
April 27, 2010, 06:52 |
Francois Gallard
Your Courant number is of 0.5, I noticed that above 0.45, with most of the schemes I used, fireFoam diverges due to numerical instability. Could you try to reduce your time step by setting the maxCo entry to 0.3 in controlDict ? Francois Last edited by fgal; April 27, 2010 at 10:28. |
Cannot run Star-CCM+ parallel in Linux | dburns | Siemens | 9 | April 27, 2010 12:01 |
Problem with Fluent Parallel | DarrenC | ANSYS | 0 | October 27, 2009 05:38 |
nonNewtonianIcoFoam - problem with parallel run | chris_sev | OpenFOAM Bugs | 4 | April 1, 2009 09:13 |
Parallel run with engineFoam | francesco | OpenFOAM Bugs | 1 | November 25, 2008 07:06 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 17:11 |
