September 2, 2009, 09:44 |
DSMC and OpenFOAM
Sebastian
Rep Power: 16 |
I want to simulate a gas flow (athmosphric pressure) around a cylindrical nanowire. I think, because of the high Kn I should use a DSMC solver. Has anybody worked with the DSMC code which comes with OpenFOAM 1.6? Thank You Sebastian |
September 3, 2009, 07:05 |
#2 | |
Hi Sebastian, what's your Kn value? |
September 3, 2009, 08:39 |
Kn Number
Sebastian
Rep Power: 16 |
Hi Ivan,
The diameter of the wire is between 40 nm and 200 nm (depends on etching - process). If I take the diameter of the nanowire as d the Knudsen-number is between 1.5 and 0,3 (I think the mean free path of air is about 60 nm at athmospheric pressure). Thanks for your reply Sebastian |
April 9, 2010, 09:26 |
Claus Schmitzer
Rep Power: 16 |
hi sparbrötchen
have u done ur simulation yet ? Is there anything I should take care of when simulating micro channels ? cheers, archy |
dsmc openfoam nems |
DSMC solver in OpenFoam | flatorre | OpenFOAM | 7 | July 28, 2010 20:04 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
