April 14, 2010, 04:37 |
Apply wallfunction in LES
Dr. Fabian Schlegel
Rep Power: 17 |
Hello Guys,
I want to apply a wall function to a wall in my LES simulation. After consulting the User Guide the boundaryField part of my 0/nuSgs file looks like this: boundaryField { top { type zeroGradient; } bottom { type nuSgsWallFunction; value uniform 1; } p1 { type cyclic; } p2 { type cyclic; } } Testing this with pisoFoam and oneEqEddy SGS Model the solver runs. If I now change the nuSgsWallFunction to e.g. "bla" nothing happens, the solver is still running without any problems. Furthermore if I apply my own wallFunction (change nuSgsWallFunction to moninObukhovWallFunction) where I added: Info << "Wall function is working " << endl; to the evaluate subroutine the solver still runs without any problems but I do not see the Info text on my screen which leads my to the assumption my wallFunction is not used. Have I forgot something to enable? Or is there a bug? kind regards, Fabian |
April 14, 2010, 08:06 |
Dr. Fabian Schlegel
Rep Power: 17 |
Allright I dont know why, but after hours of trying it works now ...
April 16, 2010, 04:03 |
Jiang
Rep Power: 16 |
I also have met the same problem. So I don't know if the solver is using the wallFunction or not.
April 16, 2010, 07:14 |
Dr. Fabian Schlegel
Rep Power: 17 |
I tested this a little bit and this is not only a problem for wall functions. OpenFoam don't check if the type of boundary condition is valid. Even if you misspelled the type but you have set a value OpenFoam assumes a fixedValue type BC as default and do not inform you about your mistake. This is not a bug, but it would be good to give a hint to the user if using default.
Display Modes | |
Is it feasible to apply implicit scheme in LES | EagleGao | Main CFD Forum | 2 | October 24, 2011 14:04 |
LES grid mesh | L3munoz | Main CFD Forum | 0 | April 7, 2010 05:05 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 05:24 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
