-   -   Laminar flow in a 3D Pipe (http://www.cfd-online.com/Forums/openfoam-solving/75342-laminar-flow-3d-pipe.html)
alquimista April 22, 2010 09:56
Hi.
I'm trying to test a laminar case. It's a 60║ pipe. It has Inlet, Outlet, Wall, and two symmetry planes.
Geometry of the pipe is: Lenght: 3 m, Radius: 0.026 m
So my files are defined as follows:
0/U:
internalField uniform (0 0 0.01);
boundaryField
Default_Boundary_Region
type fixedValue;
value uniform (0 0 0);
inle_1
type fixedValue;
value uniform (0 0 0.01);
pres_2
type zeroGradient;
symplane_3
type symmetryPlane;
symplane_4
type symmetryPlane;
/0/p
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
type zeroGradient;
inle_1
type zeroGradient;
pres_2
type fixedValue;
value uniform 0;
symplane_3
type symmetryPlane;
symplane_4
type symmetryPlane;
constant/transportProperties
nu nu [ 0 2 -1 0 0 0 0 ] 1e-06;
system/fvSolution
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
And tipical schemes for this case.
When I solve it by icoFoam and I run paraFoam I can see the results are bad, the ux and uy velocities has high positive and negative values. I don't know why....
I tried with different inlet velocities too.
http://www.imaxenes.com/mini/ux1oo58vq.jpeg
http://www.imaxenes.com/mini/uy1xx14tw.jpeg
http://www.imaxenes.com/mini/uz1ij83k5.jpeg
Thanks in advancedí
alquimista April 24, 2010 10:50
I just have solved it. It seems to be that there was a problem with paraView.
After I added in the paraFoam script the line export LC_ALL=C I saw the results ok.
Reference post:
http://www.cfd-online.com/Forums/ope...-paraview.html
