Laminar flow in a 3D Pipe
Old   April 22, 2010, 09:56
Default Laminar flow in a 3D Pipe
alquimista is on a distinguished road
Hi.
I'm trying to test a laminar case. It's a 60º pipe. It has Inlet, Outlet, Wall, and two symmetry planes.
Geometry of the pipe is: Lenght: 3 m, Radius: 0.026 m
So my files are defined as follows:
0/U:
internalField uniform (0 0 0.01);
boundaryField
Default_Boundary_Region
type fixedValue;
value uniform (0 0 0);
inle_1
type fixedValue;
value uniform (0 0 0.01);
pres_2
type zeroGradient;
symplane_3
type symmetryPlane;
symplane_4
type symmetryPlane;
/0/p
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
type zeroGradient;
inle_1
type zeroGradient;
pres_2
type fixedValue;
value uniform 0;
symplane_3
type symmetryPlane;
symplane_4
type symmetryPlane;
constant/transportProperties
nu nu [ 0 2 -1 0 0 0 0 ] 1e-06;
system/fvSolution
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
And tipical schemes for this case.
When I solve it by icoFoam and I run paraFoam I can see the results are bad, the ux and uy velocities has high positive and negative values. I don't know why....
I tried with different inlet velocities too.
Thanks in advanced¡
alquimista is offline   Reply With Quote
Old   April 24, 2010, 10:50
I just have solved it. It seems to be that there was a problem with paraView.
After I added in the paraFoam script the line export LC_ALL=C I saw the results ok.
Reference post:
http://www.cfd-online.com/Forums/ope...-paraview.html
Using a turbulent model when the flow is entirely laminar. mwhyte FLUENT 1 June 7, 2012 10:35
gravitational acceleration in laminar pipe flow atmcfd ANSYS 0 January 4, 2010 22:19
Flow laminar and stationary of water in a pipe manuel OpenFOAM Running, Solving & CFD 6 March 24, 2007 18:23
First steps - laminar flow in a pipe Maria Phoenics 8 November 27, 2001 11:26
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
