How to compile an unsteady solver based on solver of MRFSimpleFoam?
hi all ,
i had a problem several days ago,but i can't resolve it yet.so i hope someone here would help me,thanks in advance! the problem is: As we know,the MRFSimpleFoam solver of OpenFOAM can't be done with unsteady flow,so i just add a PISO loop to modify it to unsteady solver. but from the picture of residuals which result from the modified solver,it appeared the result of steady solver does. i don't know where is the error.would someone help me? the modified code file is : \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H" #include "incompressible/RASModel/RASModel.H" #include "MRFZones.H" #include "IFstream.H" #include "OFstream.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createMesh.H" # include "createFields.H" # include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; for (runTime++; !runTime.end(); runTime++) { Info<< "Time = " << runTime.timeName() << nl << endl; # include "readPISOControls.H" # include "CourantNo.H" // Pressure-velocity SIMPLE corrector { // Momentum predictor tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) ); mrfZones.addCoriolis(UEqn()); UEqn().relax(); solve(UEqn() == -fvc::grad(p)); //PISO loop for (int corr=0;corr<nCorr;corr++) { volScalarField rAU = 1.0/UEqn().A(); U = rAU*UEqn().H(); phi = (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rAU,U,phi); adjustPhi(phi, U, p); p.boundaryField().updateCoeffs(); mrfZones.relativeFlux(phi); // Non-orthogonal pressure corrector loop for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phi) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); if (nonOrth == nNonOrthCorr) { phi -= pEqn.flux(); } } # include "continuityErrs.H" // Explicitly relax pressure for momentum corrector p.relax(); // Momentum corrector U -= rAU*fvc::grad(p); U.correctBoundaryConditions(); } } turbulence->correct(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return(0); } // ************************************************** *********************** // regards! |
