April 27, 2010, 11:12 |
fixedValue BC not fixed
Nick Gardiner
Rep Power: 17 |
Hi
I'm trying to simulate a blade of a crossflow turbine rotating about a central axis using TurbDyMFoam. The simulation runs ok except that the velocity on the blade does not stay at (0,0,0) as specified in the initial boundary condition: Blade { type fixedValue; value uniform (0 0 0); } Instead it climbs much higher than the other values in the boundary layer. The attached pics show two close ups of the blade's leading edge with velocity vectors (and pressure contour). Can anyone tell me how come the velocity on the blade is not 0 and how do I fix it? Do I need a movingWallVelocity (0,0,0)? Many thanks Nick |
April 28, 2010, 10:04 |
Nick Gardiner
Rep Power: 17 |
The movingWallVelocity isn't the answer
Display Modes | |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
FOAM FATAL IO ERRORsimpleFoam | hariya03 | OpenFOAM Running, Solving & CFD | 6 | July 16, 2008 08:03 |
UDF: source, fixed value for a given region | Ming | FLUENT | 1 | March 4, 2003 17:23 |
Has the pressure to be fixed at one node? | Steve Song | Main CFD Forum | 5 | February 9, 2003 13:14 |
