Home > Forums > OpenFOAM Running, Solving & CFD
groovyBC does not compile
Old   May 4, 2010, 04:14
Question groovyBC does not compile
Marc Redmer
Marc_r is on a distinguished road
i'm trying to compile groovyBC(1.6) for FOAM 1.6x
Got the new versions of bison and m4
bison (GNU Bison) 2.4.1
m4 (GNU M4) 1.4.14
It's probably somthing with:
NONE:0: /usr/bin/m4: ERROR: EOF in string
bison: subsidiary program `/usr/bin/m4' failed (exit status 1)
but i'm somehow lost.
Already looked at a similar post here
Transient boundary conditions
Heres the complete output:
[groovyBC] wmake libso
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file PatchResult.C
Making dependency list for source file PatchValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
Making dependency list for source file PatchValueExpressionLexer.ll
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll
Making dependency list for source file PatchValueExpressionDriver.C
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C
Making dependency list for source file groovyBCFvPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCFvPatchFields.C
Making dependency list for source file groovyBCPointPatchFields.C
could not open file MixedPointPatchField.H for source file groovyBCPointPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCPointPatchFields.C
could not open file PointPatchFieldMapper.H for source file groovyBCPointPatchFields.C
SOURCE=PatchResult.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/efs/Software/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/efs/Software/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/efs/Software/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchResult.o
PatchResult.C: In member function »void Foam::PatchResult::uglyDelete()«:
PatchResult.C:97: Warnung: Löschen von »void*« ist nicht definiert
SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linux64GccDPOpt/PatchValueExpressionParser.C Make/linux64GccDPOpt/PatchValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linux64GccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linux64GccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linux64GccDPOpt ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/efs/Software/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/efs/Software/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/efs/Software/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/PatchValueExpressionParser.C -o Make/linux64GccDPOpt/PatchValueExpressionParser.o
mv: Aufruf von stat für »*.tab.cc« nicht möglich: Datei oder Verzeichnis nicht gefunden
mv: Aufruf von stat für »*.tab.hh« nicht möglich: Datei oder Verzeichnis nicht gefunden
g++: Make/linux64GccDPOpt/PatchValueExpressionParser.C: Datei oder Verzeichnis nicht gefunden
g++: keine Eingabedateien
make: *** [Make/linux64GccDPOpt/PatchValueExpressionParser.o] Fehler 1
Every guess is welcome
Regards,
Marc
Marc_r is offline   Reply With Quote
Old   May 10, 2010, 05:40
Assistant Moderator
Bernhard Gschaider
Originally Posted by Marc_r View Post
m4 (GNU M4) 1.4.14
Regards,
Marc
No idea. Looks to me like the temporary m4-file that bison generates was not correctly written. Check whether you did not hit the quota on your system and there is space left on /tmp (but this is just a wild guess). If you have access to another machine try it on that too, just to be sure
Bernhard
Old   May 26, 2010, 14:53
Default groovyBC
Joseph
tamsilian is an unknown quantity at this point
Hi
i simulated polymer in extruder(screw mill) by ViscoElastic fluidFoam,Jovani. According to my geometry, velocity vectors in boundary condition are changed .As result i should code variables condition in 0File>> U>> movingWalls.do you know that GroovyBC was compiled to OpenFoam as defualt or i have to compile it?and how to compile groovyBC to OpenFoam v.1.6?if anybody coded one geometry by groovyBC this is thanksful to sent it me by tamsilian@gmail.com.
Thanks in advanced your help
tamsilian is offline   Reply With Quote
Old   May 26, 2010, 18:59
Assistant Moderator
Bernhard Gschaider
Originally Posted by tamsilian View Post
Hi
This is the 6th instance of the same question. Spamming the message board is the best way to get NO answer to your question (nevertheless at least one of these questions got an answer, so why do you continue asking?)
Old   November 4, 2010, 13:20
Wai Sam Wong
anthropoy is on a distinguished road
Hi Marc_c
Did you manage to resolve this compile error? I've got the same problem too.
Thanks!
Sam
anthropoy is offline   Reply With Quote
Old   November 4, 2010, 14:29
Default Help
Joseph
Dear Sir/Madam. Fortunatelt, I would solved this problem. this problem was orginated by your GroovyBC file that was donloawded from related site. Please, send your email to me until i can mail the suitable groovyBC file.
TNX
Joseph
groovybc, tab.cc, tab.hh
Thread Tools
Trackbacks are On
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 32 May 8, 2015 06:05
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 22:51
compile the UDF Li Jingping FLUENT 2 April 14, 2003 21:18
