[Sponsors] | |||||
Rep Power: 5 ![]() |
Hello all!
I am new in using OpenFoam! I prepared a implicite case for rhoPorousSimpleFoam like the tutorial case. But my calculation always stops after few timesteps. From begin I get a "time step continuity error". It stops with "maximum numbers of iterations exceeded" .To prevent this, I reduced the timestep and toyed with the relaxation factors, but all does not help to solve the problem. I have yet solved the problem in a explicite case. This was only possible with very small relaxation factors. But the result doesn't fit well to the calculation with fluent. So I hope to get a better result with a implicite case. My task is to simulate the flux through a catalyst. My mesh has 460000 cells. If you need more information, easily tell me. Thanks in advance! Greets Chris |
Here is my error message:
Maximum number of iterations exceeded#0 Foam::error:.printStack(Foam::Ostream&) in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::hPsiThermo<Foam:.pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" #3 Foam::hPsiThermo<Foam:.pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" #4 main in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoPorousSimpleFoam" #5 __libc_start_main in "/lib64/libc.so.6" #6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ho to model the flow in a Regenerator | alexandrepereira | OpenFOAM Running, Solving & CFD | 2 | August 25, 2010 17:35 |
| RhoPorousSimpleFoam RhoSimpleFoam | spv24 | OpenFOAM Running, Solving & CFD | 4 | November 12, 2008 09:19 |
