rhoPorousSimpleFoam
Old   May 5, 2010, 04:54
Default rhoPorousSimpleFoam
Chrisi1984 is on a distinguished road
Hello all!
I am new in using OpenFoam!
I prepared a implicite case for rhoPorousSimpleFoam like the tutorial case. But my calculation always stops after few timesteps.
From begin I get a "time step continuity error".
It stops with "maximum numbers of iterations exceeded" .To prevent this, I reduced the timestep and toyed with the relaxation factors, but all does not help to solve the problem.
I have yet solved the problem in a explicite case. This was only possible with very small relaxation factors. But the result doesn't fit well to the calculation with fluent. So I hope to get a better result with a implicite case.
My task is to simulate the flux through a catalyst. My mesh has 460000 cells.
If you need more information, easily tell me.
Thanks in advance!
Greets
Chris
Chrisi1984 is offline   Reply With Quote
Old   May 5, 2010, 05:36
Default error message
Here is my error message:
Maximum number of iterations exceeded#0 Foam::error:.printStack(Foam::Ostream&) in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:.pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:.pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 main in "/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoPorousSimpleFoam"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68.
Ho to model the flow in a Regenerator alexandrepereira OpenFOAM Running, Solving & CFD 2 August 25, 2010 17:35
RhoPorousSimpleFoam RhoSimpleFoam spv24 OpenFOAM Running, Solving & CFD 4 November 12, 2008 09:19
