continuity error
Hi all,
i am new to OpenFoam andi want to simulate a vacuum-chamber pumpdown. So there is no inlet and only one outlet. At the outlet i use a fixed velocity-value and zeroGradient pressure. When i run pisoFoam it crashes after a few iterations because of a continuity error and advises me to run potentialFoam to initialise the outflow. But when i run potentialFoam it crahses during the first iteration. Are there any special requirements for the B, k, nuSgs or nuTilda files when there is no inlet? Should i try other solvers? What kind of type should the outlet be? inletOutlet or something else? I would be pleased if anyone can help me! |
pisoFoam is an incompressible solver, so I don`t think that is is suitable for your case.
thanks for your fast reply.
Of course you are right:) now i have copied alphaSgs,... out of a tutorial and modified the BC for my case. then i want to solve this with rhoPisoFoam and get the following error: Selecting turbulence model type LESModel Selecting LES turbulence model oneEqEddy Different dimensions for = dimensions : [1 -1 -1 0 0 0 0] = [0 2 -1 0 0 0 0] #0 Foam::error::printStack(Foam::Ostream&) in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::dimensionSet::operator=(Foam::dimensionSet const&) const in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::operator=(Foam::tmp<Foam::Geometri cField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/fabian/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/rhoPisoFoam" #4 Foam::compressible::LESModels::oneEqEddy::updateSu bGridScaleFields() in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleLESModels.so" #5 Foam::compressible::LESModels::oneEqEddy::oneEqEdd y(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleLESModels.so" #6 Foam::compressible::LESModel::adddictionaryConstru ctorToTable<Foam::compressible::LESModels::oneEqEd dy>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleLESModels.so" #7 Foam::compressible::LESModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleLESModels.so" #8 Foam::compressible::turbulenceModel::addturbulence ModelConstructorToTable<Foam::compressible::LESMod el>::NewturbulenceModel(Foam::GeometricField<doubl e, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleLESModels.so" #9 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/fabian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleTurbulenceModel.so" #10 main in "/home/fabian/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/rhoPisoFoam" #11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #12 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 From function dimensionSet::operator=(const dimensionSet& ds) const in file dimensionSet/dimensionSet.C at line 143. You have any idea where the problem is? |
i know it has something to do with the density, but what dimensions should i change?
alphaSgs and muSgs are (1 -1 -1 0 0 0 0) nuSgs and nuTilda are (0 2 -1 0 0 0 0) |
