May 28, 2010, 00:08 |
problem running the sonicFoam
subash
Rep Power: 16 |
I tried to simulate a supersonic flow over a ramp, for this I selected the thermophysical models to be hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> when I use the above models I get the following error Not implemented#0 Foam::error:rintStack(Foam::Ostream&) in "/home/research/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/research/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::basicThermo::e() in "/home/research/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #3 main in "/home/research/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/sonicFoam" #4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #5 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/i386/elf/start.S:122 can anyone help me to decode this error message. Thank you. |
June 25, 2010, 06:39 |
Yu
Rep Power: 15 |
Try using ePsiThermo instead of hPsiThermo
July 28, 2010, 14:23 |
basicThermo error
Tom
Rep Power: 17 |
I have been getting the same error using hPsiThermo.
I have tracked it back to ~/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels/basic/basicThermo/basicThermo.C The error leads to this section of code. Foam::volScalarField& Foam::basicThermo::e() { notImplemented("basicThermo::e()"); return const_cast<volScalarField&>(volScalarField::null() ); } I was able to get my program working by switching to ePsiThermo, but shouldn't it work equally well with hPsiThermo? |
Display Modes | |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Problem running buoyantFoam | anke | OpenFOAM | 4 | August 28, 2013 04:43 |
Problem running parallel | Hernán | Main CFD Forum | 0 | December 22, 2009 04:36 |
the problem of running star-cd after pro-star | liu-jinsong | Siemens | 0 | November 20, 2008 20:58 |
problem running parallel-help needed | Shankar | FLUENT | 0 | December 16, 2002 13:45 |
