trying to run OpenFOAM using python sending commmand lines
Old   February 23, 2021, 15:02
Question trying to run OpenFOAM using python sending commmand lines
Ash Kotwal
Ash Kot is on a distinguished road
Hello Foamers,
how to run follwing command:
mpirun -np 4 interFoam -parallel > log & tail -f log
using python as command line in terminal?
My perpose is to run the command, simlutaniouly show the running log in terminal, as well as read the 'log' file using the python script and once it read the message ''Finalising Parallel run" in that log file then run follwing command:
pkill interFoam
Ash Kot is offline   Reply With Quote
Old   February 23, 2021, 17:02
Ash Kotwal
Hello All,
How to write PyFoam equivalent script for the above defined command, which is:
Old   February 25, 2021, 19:30
Ash Kotwal
Anyone know how to use PyFoam and convrt above mentioned command and make OpenFOAM simulation run through PyFoam?
Essntially, I'm trying to run PyFoam code which will equivalantly execute the below given code:
automation, openfoam 7, python script
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 03:05
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 19:00
Python for openfoam Divyaprakash OpenFOAM Programming & Development 1 August 22, 2014 09:05
