MRFInterFoam: Trouble with direction of gravity / Continuity error cannot be removed |
May 28, 2010, 11:15 |
Dear Foamers,
I've modified the mixerVessel2D in order to simulate a rotating shaft (cylinder) within a circular housing using MRFInterFoam. The housing is filled with oil up to the centre (fluid fraction 50%), and, accordingly, gravity is set to the -y direction. The problem I'm facing now is that I can't get the solver running due to the following error: FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Without gravity or with gravity acting in -z-direction (parallel to the rotational axis), there is no problem. Boundary conditions are set according to the tutorial case. Changing the pressure bc to buoyantPressure doesn't have any effect. What am I doing wrong??? Any ideas or help are greatly appreciated!! Kind regards, have a nice weekend Bengt |
May 28, 2010, 14:45 |
problem persists
Hi nima,
thanks a lot for your reply!! Indeed, reducing the timestep/maxCo gets the solver working with the fluid fraction remaining constant - however, after 2 seconds it crashes giving the same error message...do you have any recommendations regarding the boundary conditions and discretization schemes / solver controls for such a case? Kind regards bengt |
continuity error, gravity, mrfinterfoam |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
