[swak4Foam] groovyBC & OpenFoam 1.7.0
Old   July 22, 2010, 04:04
Default groovyBC & OpenFoam 1.7.0
val46 is on a distinguished road
i'm using OF1.7.
I would like to install groovyBC and downloaded it from
https://openfoam-extend.svn.sourcefo...ries/groovyBC/
Unfortunetaly I got tons of errors like:
/home/kressnt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/sphericalTensor.H:43: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘Foam’
Do you have any ideas how to install it proberly?
Thanks in advance
Toni
val46 is offline   Reply With Quote
Old   July 22, 2010, 09:27
Assistant Moderator
Bernhard Gschaider
Originally Posted by val46 View Post
i'm using OF1.7.
Thanks in advance
Toni
This looks like a very fundamental problem with your compiler and/or your installation. Have you ever compiled anything else for that installation?
I just tried and groovBC from the 1.6-section of the Breeder compiles without problems on my 1.7.x-installation
Bernhard
Old   July 22, 2010, 10:25
Hi Bernard,
thanks for your quick reply.
Hm... what do you mean? The whole OF1.7 installation is working probably.
What else to I have to compile?
Regards,
Toni
Old   July 22, 2010, 13:27
Assistant Moderator
Bernhard Gschaider
Hi Bernard,
Regards,
Toni
Have you ever compiled any other Third-Party-contribution? It is my suspicion that you're facing the same problem there. OR that you stumbled upon a very rare compiler problem (unlikely, but what compiler are you using)
Bernhard
Old   July 23, 2010, 02:23
I compiled ParaView3.8.0 and it worked.
I'm using Suse 11.2 with gcc 4.4.1
Old   July 23, 2010, 04:02
Assistant Moderator
Bernhard Gschaider
Sorry. I was a bit unspecific. I meant "ThirdParty-OpenFOAM software that has to be compiled using wmake". Some solver, util etc
Bernhard
Old   July 23, 2010, 05:04
No.
I just followed the official installation instructions for OF and recompiled the icofoam solver because i changed the code.
Old   July 23, 2010, 07:44
Assistant Moderator
Bernhard Gschaider
No.
Strange. Because the file that raises the error is not one of groovyBC
Old   July 23, 2010, 09:11
As I said, this was just an example from the whole error message. Overall i got thousands of errors but all with the same pattern (see the attached file).
What else could i have done wrong?
1. I updated Bison on 2.4.1
2. I downloaded the files from the path I mentioned above
3. I unpacked the files in a separat folder (no OF path)
4. I typed "wmake libso" in the groovyBC folder
Old   August 3, 2010, 08:30
Assistant Moderator
Bernhard Gschaider
OK. The trouble starts here:
SOURCE=PatchResult.c ;  gcc -m64 -Dlinux64 ...
For some reason you're compiling PatchResult.c (with a lowercase c) where it should be PatchResult.C. The compiler/wmake interprets this as a C-file and chokes at some C++-constructs (probably the namespace)
Bernhard
Old   August 6, 2010, 04:16
Hi Bernard,
thanks for Reply.
I changed all .c-files to .C-files. After that I had to edit also all the .dep-files.
Than i started wmake again.
No luck so far... i attached the error message.
Regards,
Toni
Old   August 9, 2010, 05:20
Assistant Moderator
Bernhard Gschaider
Hi Bernard,
thanks for Reply.
Regards,
Toni
No idea. It still gets compiled as C
SOURCE=PatchValueExpressionDriver.C ;  gcc -m64 -Dlinux64 -DWM_DP -Wall -O3  -IMake/linux64GccDPOpt  -I/home/kressnt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/kressnt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/kressnt/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchValueExpressionDriver.o
but at least now the compiler seems to know that this is a C++-source
/home/kressnt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/lduInterface.H:102: error: ISO C++ forbids declaration of ‘Pstream’ with no type
Looks like the Pstream was included but for some reason not "looked at".Try the following. Execute
SOURCE=PatchValueExpressionDriver.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -O3  -IMake/linux64GccDPOpt  -I/home/kressnt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/kressnt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/kressnt/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchValueExpressionDriver.o
from the command line. If that doesn't help insert
#include "Pstream.H"
near the beginning of PatchValueExpressionDriver.C
Something is very strange with your setup
Bernhard
Old   August 11, 2010, 03:58
I tried both with no success...
Inserting #include "Pstream.H" changed nothing.
Old   August 11, 2010, 04:32
Assistant Moderator
Bernhard Gschaider
Could I suggest that you try again from a completely fresh copy of the sources (by downloading it in the way suggested on the Wiki-page via svn) as you had to rename your original files and nobody knows what else is lurking there
Bernhard
Old   August 11, 2010, 06:46
Oh my god! It works!
I'm sitting behind a powerful firewall. That's why I'm not able to use the svn command from the terminal. I have to download it by hand. Maybe I messed something up while I downloaded and saved the files.
Sorry, Bernard, if I wasted your time with that.
Thanks for your help anyway.
Toni
Old   August 11, 2010, 10:27
Assistant Moderator
Bernhard Gschaider
There is an alternate Webinterface to Subversion on Sourceforge.net that allows to download whole directories as tar-balls (click around a bit, should be accessible from the project-page)
Could we agree on "Your IT-department wasted both of our time by denying you access to essential services on the net"?
Old   August 13, 2010, 02:36
Hm... couldn't find anything like that.
Jepp, we could do that
Old   August 13, 2010, 05:10
Assistant Moderator
Bernhard Gschaider
http://openfoam-extend.svn.sourcefor...-extend/trunk/
Browse to the directory you want and press "Download GNU tarball"
Old   August 20, 2010, 13:10
Shoonya is on a distinguished road
I down loaded from this link
just typed on terminal as
svn checkout https://openfoam-extend.svn.sourcefo...aries/groovyBC
for this I had to first install subversion as
$ sudo apt-get install subversion
before this I was downloading groovyBC from some other link ...that was creating error as
make: *** [Make/linux64GccDPOpt/PatchValueExpressionDriver.o] Error 1
the link mentioned above is from wiki and works well...
Shoonya is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
[swak4Foam] groovyBC OpenFoam 1.7 dandalf OpenFOAM Community Contributions 7 March 18, 2011 05:19
Installation of OpenFOAM 1.7.0 on SLED10SP2 olauer OpenFOAM Installation 2 June 30, 2010 10:29
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
