Boundary condition
Old   May 31, 2010, 10:52
Default Boundary condition
Daniele
Daniele111 is on a distinguished road
Hi All
If i want impose BC, in k-s model, for k, epsilon and U on inlet ma not pressure, How change 0/p file?
Thanks
Daniele111 is offline   Reply With Quote
Old   May 31, 2010, 12:54
Daniele
I simulate atmospheric boundary layer and on outlet I impose zero gradient for the pressure, but in the paper that I use like reference don't speak about pressure condition on other part of boundary.
Old   May 31, 2010, 13:10
Daniele
And when I run my case i have this error:
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.88883e-21, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0159314, No Iterations 2
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00459912, No Iterations 15
time step continuity errors : sum local = 17748.9, global = 66.9892, cumulative = 66.9892
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/acconcia/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
in "/home/acconcia/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/simpleFoam"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
Idea????
Old   June 1, 2010, 07:41
Francois Gallard
fgal is on a distinguished road
Hi Daniele,
The solver does not accomplish the resolution of the linear systems properly. This can come from the boundary conditions, the mesh, the numerical schemes or their combination...
You could try first to use smoothSolver and GaussSeidel instead of DILU in your system/fvSolution file, which seems to be more efficient in my experience :
solver smoothSolver;
smoother GaussSeidel;
tolerance 1e-8;
relTol 0;
nSweeps 1;
Hope it helps...
fgal is offline   Reply With Quote
Old   June 9, 2010, 14:32
Daniele
Hi
Someone just simulated atmospheric boundary layer? What are correct boundary condition for p? An k epsilon? Is correct use wallShearStress to compute the stress at bottom?
Best regards
Old   June 10, 2010, 11:54
Daniele
What is there of wrong in my boundary condition for atmospheric boundary layer? Help me thanks!
Best regards
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
Transient outlet boundary condition problem jwillie2000 CFX 1 December 7, 2009 17:07
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
How to resolve boundary condition problem? sam FLUENT 2 July 20, 2003 02:19
