OF16ext GGI - divergence after a rotation of ~ 180 degree |
October 17, 2012, 02:07 |
#1 | ||
Andreas Wendy
Rep Power: 13 |
Hi everybody,
I am trying to run some simulations with the OF16ext and ggi. I have an outer field where all boundaries set to zeroGradient. (Velocity and pressure) I have an internal rotating mesh with a fixed rotational speed of 300 rounds per minute. At the beginning of the calculation everything goes fine. But at an angle around 180° my simulations just gets totally wrong. see this gif animation: http://ubuntuone.com/0yQl0kh42shqy6PHS6m6MW My thought is the problem lies within the ggi pair which gets posted in the log file. The values are growing by the time steps. Does anyone know what exactly this ggi pair logging says? ggi pair at beginning Quote:
Best wishes Andy |
October 17, 2012, 06:41 |
Rep Power: 15 |
Hi Andreas,
I would suggest first of all to check how the mesh looks like at the end of your simulation. From what you say, I think your mesh did not slide properly. Cheers Ivan |
divergent, ggi, icodymfoam, of16ext |
Create a GeometricField of a given type on given patch? | philippose | OpenFOAM Programming & Development | 4 | August 12, 2013 12:41 |
reconstructPar failed with OF16ext and GGI | A.Wendy | OpenFOAM Post-Processing | 0 | September 13, 2012 01:45 |
Axisymmetric Grid | N. A. | OpenFOAM | 5 | July 2, 2010 10:39 |
tow phase flow in 180 degree bend | akbar | FLUENT | 0 | January 28, 2004 15:52 |
Flow in 180 Degree Bend | Abhijit | Main CFD Forum | 9 | November 7, 2002 09:44 |
