June 7, 2010, 04:11 |
rotating gravity
Oli
Hello World.
Is it possible to read the gravity-File g time dependent vom a data-File? (similar to timeVaryingUniformFixedValue) This could be an easy way to simulate a rotation. Best Regards. |
June 7, 2010, 07:40 |
should not pose a problem
Roman Thiele
Rep Power: 20 |
This should not pose a problem. One thing though is that you will have to modify a solver and add a gravity file to your time folders. This can then be read like any other field from the the runtime.
I would suggest that you take a look on how to implement new fields to an existing solver.
~roman |
Rotating Impeller | Naith | FloEFD, FloWorks & FloTHERM | 22 | November 5, 2012 08:53 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 06:14 |
stress analysis of a rotating beam(wind blade) | Cheyannne | ANSYS | 0 | October 19, 2009 17:06 |
Gravity in single rotating reference frame | QinxueTan | FLUENT | 0 | May 7, 2008 06:59 |
On gravity modelling... | Drona | CFX | 7 | November 22, 2001 10:28 |
