June 4, 2010, 06:38 |
BuoyantBoussinesqSimpleFoam solver algorithm
Hello all,
I've used this solver for a run, but the results showed not very satisfactory. I'm trying to understand if it is out of setup problems or the algorithm of this solver. Has someone experience (validation assessment) using it? I've read the wiki documentation for BuoyantBoussinesqPisoFoam and here are some changes between Simple and Piso. The following operations for UEqn: fvm::div(phi,U) -fvm::Sp(fvc::div(phi), U) +turbulence->divDevReff(U) What does the second operation do? Sp(...) From math point of view, is it essentially the same as Piso except the transient term? Best Regards, walker |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
