June 29, 2010, 14:30 |
change boundary condition on the fly
Xiaofeng Liu
Rep Power: 17 |
It there a way to change the BC type during simulation?
I have a cavity whose top is a symmetry plane except a small patch where some fluids will be injected for 5 s. After the injection (the injecting needle will be removed), I want that small patch to be symmetry patch also. How do I code this? Or is there a way to do it? Right now, I have to run two simulations (with and without the injection patch) and then map the solutions. |
Use DEFINE_ADJUST change boundary condition | liurengtong123 | Fluent UDF and Scheme Programming | 29 | January 14, 2024 00:56 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Pressure Boundary Condition | Matt Umbel | Main CFD Forum | 0 | January 11, 2002 10:06 |
UDF, using DEFINE_ADJUST to change a boundary condition | Jonas Larsson | FLUENT | 4 | March 21, 2000 18:51 |
