-   -   non zero divergence for incompressible flow! (http://www.cfd-online.com/Forums/openfoam-solving/77256-non-zero-divergence-incompressible-flow.html)
Pascal_doran June 17, 2010 16:16
Hi all,
I'm simulating wake vortices in ground effect. I use icoFoam (incompressible) solver. But when I compute the divergence of U, I find non zero divergence (~-0.5 to 0.5).
I compute the divergence with : foamCalc div U and my own utility (using Gauss linear scheme). Both way I got the same results (with a difference less then 1%).
Can somebody explain me why I have such high divergence (I'm not expecting to have div(U) = 0 but more like div(U) ~= 0.01)
Thank you,
Pascal
rieuk June 18, 2010 08:06
Hey Pascal,
Have you checked for convergence at each time-step (like looking at the initial residuals)? Maybe you need to increase your nCorr (number of PISO corrector steps)? Just guessing...
alberto June 18, 2010 10:36
You must check div(phi), using the phi coming out from the pressure equation, not div(U).
Actually the code does that for you when it prints the local and global continuity error. Search for the file continuityErrs.H to check.
Best,
Pascal_doran June 18, 2010 18:46
Thank you for your help
But can you explain me why it is better to check div(phi) than to check div(U) both should be near zero? And by the way what is a good value for div(U) and div(phi) for an incompressible flow (I know that in theory it should be div(U) = 0 ...)
Pascal
alberto June 18, 2010 19:16
Hi Pascal,
It is a question of consistency with how you discretise and solve the equations.
Short answer: you impose div(phi) = 0, meaning div(U_f) = 0, being U_f the velocity on the cell faces, not div(U) = 0, being U the velocity in cell centers.
Long answer: If you go through the derivation, you can think to semi-discretize the momentum equation as
A*U = H - grad(p)/rho
so that
U = (H/A) - grad(p)/(A*rho)
At this point you use the continuity equation
div(phi) = div(Uf) = 0
The continuity equation tells you the divergence of the flux is zero, and the flux is computed at cell faces, not at cell centres.
By interpolating the predicted U, obtained from the semi-discrete momentum equation, you get (S is the surface area vector, and |S| its norm)
phi = Uf = (H/A)_f - snGrad(p)/(rho*A)_f |S|
and, replacing this in the continuity equation
div((H/A)_f) - laplacian(1/(rho*A)_f |S|, p) = 0
Note that in OpenFOAM phi is computed as
phi = fvc::interpolate(U) + ddtPhiCorr(rUA, U, phi)
where U = H/A, and rUA = 1/A. The term ddtPhiCorr originates from the collocated grid arrangement.
Very small. Take a look at icoFoam tutorials for the cavity case, which return something like:
time step continuity errors : sum local = 8.06059e-09, global = 9.28097e-19, cumulative = 9.00754e-18
Best,
Pascal_doran June 18, 2010 19:52
Thank you Alberto!
I really appreciate the short and long answer! It really helps me.
Regards,
Pascal
rieuk June 18, 2010 23:00
But U_f and U should the same velocity distributions (or almost since U_f is just the interpolated U at cell surfaces) so why should the divergence be different for each of them?
pbohorquez June 19, 2010 11:00
Hi Pavan:
icoFoam solves for the integral form of Navier-Stokes equations. Therefore, you should compute the mass imbalance (in the computational cell) as the integral of div(U) in the cell volume V_P. Subsequently, you should apply Gauss theorem to transform the volumetric integral of div(U) as the sum of phi on the face. Do you know what does div(phi) mean?
rieuk June 19, 2010 21:42
Thanks Patricio, I forgot about the way it's calculating div in the discrete space.
alberto June 20, 2010 15:31
Maybe we should put this in the wiki FAQ :D
Pascal_doran September 20, 2010 16:17
Hi Alberto,
Do you have an idea how to compute the vorticity based on the flux phi like this :
curl(phi)
When I tried to compiled I got this error message :
zVorticityPhi.C:82: error: no matching function for call to ‘curl(Foam::surfaceScalarField&)’
make: *** [Make/linux64GccDPOpt/zVorticityPhi.o] Error 1
Here the main part of my code:
        IOobject phiheader
            "phi",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
    if (phiheader.headerOk())
        Info<< "    Lecture de phi" << endl;
        surfaceScalarField phi(phiheader, mesh);
        Info<< "    Calcul de vorticity" << endl;
        volVectorField vorticity
            IOobject
                "vorticity",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ
            fvc::curl(phi)
Thank you,
Pascal
alberto September 20, 2010 16:38
Hello, phi is a scalarField, so curl(phi) is not defined. You have to use a vectorField to compute the curl.
Best,
Pascal_doran September 20, 2010 17:18
Thanks for your reply,
So are you saying that I can't compute vorticity directly from the flux? Because phi must be a surfaceScalar and the vorticity must a volVector. What are you suggesting me to do since div(phi) is more accurate than div(U) I guess that curl based on phi would be more accurate than the curl based on U? What do you think?
Pascal
alberto September 20, 2010 17:23
What do you use the vorticity for?
Pascal_doran September 20, 2010 17:27
I use the vorticity for tracking the position of wake vortices and for stability analysis.
alberto September 20, 2010 17:36
What I said is phi is a scalar quantity (it is the U_f \cdot surface), while the curl operation is only defined for vectors.
The U in cell centres, which is what you visualize in paraview is not "inaccurate". It does not satisfy the continuity equation strictly, since the continuity constraint is applied to the flux.
Best,
pbohorquez September 21, 2010 05:09
Pascal
Hi Pascal,
that is a good question. But how can you relate phi with curl(U)? May be I am wrong, but I think that Gauss theorem cannot be applied to curl operator in order to express a volume integral as surface integrals. So I have difficulties to figure out a way of implementing a "conservative" discretization of curl. I think that it is usually treated as a source term.
To visualize vortex shedding you can just employ the "vorticity" command implemented by default in OF, and select the component to visualize in paraView. In the presence of non-orthogonal cells you may find jumps at element boundaries, as discussed in Tomboulides and Orszag (JFM, 2000, 416:45-73), so take care of them. I will post a nice picture showing vortex sheding in the near future.
Best wishes,
Patricio
Pascal_doran September 21, 2010 10:22
Hi Patricio,
I think you're totally right. I was just wondering what was the most efficient way to compute the vorticity. In my case the mesh is orthogonal :) so I will keep using the vorticity utility.
Thanks
Pascal
