polynomial thermophysical properties II
Like Tree3Likes
Old   June 18, 2010, 03:05
Default polynomial thermophysical properties II
Sebastian Saegeler
sebastian is on a distinguished road
I know, this question has already been discussed (http://www.cfd-online.com/Forums/ope...roperties.html). But the answer has not been very helpful to me.
I am having exactly the same problem. Im trying to use the hPolynomialThermo for a temperaturedependent Cp.
hPsiMixtureThermo<pureMixture<sutherlandTransport< specieThermo<hPolynomialThermo<perfectGas>>>>
or
hPsiMixtureThermo<pureMixture<constantTransport<sp ecieThermo<hPolynomialThermo<perfectGas>>>>
But OpenFoam gives back
Unknown basicPsiThermo type hPsiMixtureThermo<pureMixture<sutherlandTransport< specieThermo<hPolynomialThermo<perfectGas>>>>>
Valid basicPsiThermo types are:
8
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<eConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>
I can not find anything on the web about that. Which conditions must be met, or which combination must be used, in order to be able to use the hPolynomialThermo?
Another question would be, how to set the polynomial? Something like that:
mixture //keyword
air 1 28.9 //specie
1035.887 -0.255611 0.0006258047 2.627558e-07 //hPolynomialThermo, polynomial for Cp
1.458e-05 110.4; //sutherlandTransport
I woud be very appreciated to get an answer . Thanks!
Sebastian
sebastian is offline   Reply With Quote
Old   June 18, 2010, 04:51
Stefan Herbert
herbert is on a distinguished road
Hi Sebastian,
I have had the same problem and solved it recently by changing thermophysicalModels/basic library. I have implemented it in a way that allows using polynomialTransport and polynomialThermo at the same time. I will point out what to do (sorry for formatting not being perfect):
  1. Add a second constructor in psiThermo/makeBasicPsiThermo.H that can take additional arguments to be able to specify the order of the polynomial to be used
    #ifndef makeBasicPsiPolyThermo_H
    #define makeBasicPsiPolyThermo_H
    #include "basicPsiThermo.H"
    #include "addToRunTimeSelectionTable.H"
    #define makeBasicPsiPolyThermo(Cthermo,Mixture,Transport,orderTransport,Thermo,orderThermo,EqnOfState)  \
    typedef Cthermo<Mixture<Transport<specieThermo<Thermo<EqnOfState, orderThermo> > , orderTransport> > >  \
        Cthermo##Mixture##Transport##orderTransport##Thermo##orderThermo##EqnOfState;                       \
    defineTemplateTypeNameAndDebugWithName        \
        Cthermo##Mixture##Transport##orderTransport##Thermo##orderThermo##EqnOfState,                       \
        #Cthermo        \
            "<"#Mixture"<"#Transport#orderTransport"<specieThermo<"#Thermo#orderThermo"<"#EqnOfState">>>>>",\
        0        \
    addToRunTimeSelectionTable        \
        basicPsiThermo,        \
        fvMesh        \
    #endif
  2. Declare your model combination in psiThermo/hPsiThermo/hPsiThermos.C (e.g. using 4th order polynomial for cp and 3rd order for transportProperties but here you can choose any order combination you want)
        hPsiThermo,
        pureMixture,
        polynomialTransport,
        3,
        hPolynomialThermo,
        4,
        perfectGas
  3. Add an modified constructor to mixtures/basicMixture/makeBasicMixture.H, too
    #include "basicMixture.H"
    #define makeBasicPolyMixture(Mixture,Transport,orderTransport,Thermo,orderThermo,EqnOfState)      \
    typedef Mixture<Transport<specieThermo<Thermo<EqnOfState, orderThermo> > , orderTransport> >      \
        #Mixture"<"#Transport#orderTransport"<specieThermo<"#Thermo#orderThermo"<"#EqnOfState">>>>>", \
        0        \
    #endif
  4. Declare your model combination again in mixture/basicMixture/basicMixtures.C
        pureMixture,
        3,
        hPolynomialThermo,
        4,
        perfectGas
In your constant/thermophysicalProperties you have to call this by using
thermoType  hPsiThermo<pureMixture<polynomialTransport3<specieThermo<hPolynomialThermo4<perfectGas>>>>>;
mixture  air
         1 //nMoles (??)
         28.32708688 //molecular weight [kg/kmol]
         0.0 //standard formation enthalpy [J/kg]
         0.0 //standard formation enthropy [J/kg]
         cpPolynomial (9.86931771e02 1.73030395e-01 6.64980490e-05 1.25487e-09)//heat capacity [J/kgK]
         muPolynomial (4.70335908e-06 4.67918313e-08 -1.09914897e-11) //dynamic viscosity [kg/ms]
         kappaPolynomial (4.64248147e-03 7.28706102e-05 -6.13777213e-09); //heat conductivity [W/mK]
I hope there are not too much mistakes caused by copy/paste .
Kind regards,
Stefan
mm.abdollahzadeh and wenxu like this.
herbert is offline   Reply With Quote
Old   June 23, 2010, 08:08
Stefan Herbert
Hi everyone,
if anyone uses this piece of code, could you please report how it works and if there arise any problems? I have already tested it but you can never be sure.
Regards,
Stefan
Old   June 24, 2010, 09:53
Chrisi1984 is on a distinguished road
Hi Herbert,
I would like to test your thermophysical model.
Is there any new compilation necessary?
Should I make a backup of may original files or should I do not change the original files and create instead of new files?
Thanks in advance!
Best regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   June 24, 2010, 10:03
Stefan Herbert
Hi Chrisi,
I'd recommend to copy the $FOAM_SRC/thermophysicalModels/basic/ to your $WM_PROJECT_USER_DIR/lib, make the changes I pointed out in my previous post and compile it to $FOAM_USER_LIBBIN. So the original files are not replaced.
To use it with your solver, you should have to edit the Make/options and recompile the solver.
Have a lot of fun
Stefan
Old   June 24, 2010, 10:15
I did exactly what you said.
But how can I complie it to $FOAM_USER_LIBBIN?
Can you give me a detailed discription how to compile everything correctly?
Regards Chrisi
Old   June 24, 2010, 10:17
Sebastian Saegeler
Hi Stefan!
Wow, thanks a lot for that detailed instruction!
I have implemented it into the Code. It compiled without an error. But when I am solving it, it gives me back an error again:
Reading thermophysical properties
ill defined primitiveEntry starting at keyword 'mixture' on line 22 and ending at line 30
file: /home/sebastian/OpenFOAM/sebastian-1.6/run_rhoSimpleThermo/constant/thermophysicalProperties at line 30.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 210.
FOAM exiting
Here, thats my thermo File:
thermoType hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hPolynomialThermo4<perfectGas>>>>>;
mixture //keyword
air 1 28.9 //specie / specieCoeffs
//1007 0 //hConstThermo / thermoCoeffs
cpPolynomial(1035.887 -0.255611 0.0006258047 -2.627558e-07) //hPolynomialThermo / thermoCoeffs
1.458e-05 110.4; //sutherlandTransport / transportCoeffs
Best wishes,
Sebastian
Old   June 24, 2010, 10:44
Stefan Herbert
Just replace
LIB=$(FOAM_LIBBIN)/libbasicThermophysicalModels
by e.g.
LIB=$(FOAM_USER_LIBBIN)/libuserBasicThermophysicalModels
in basic/Make/files and compile with wmake libso.
Later in your solvers Make/options replace -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude by -I$(WM_PROJECT_USER_DIR)/lib/"path to your lnInclude" and for EXE_LIBS replace -lbasicThermophysicalModels by $(FOAM_USER_LIBBIN)/libuserBasicThermophysicalModels.so
Hope it helps,
Stefan
mm.abdollahzadeh likes this.
Old   June 24, 2010, 10:48
Stefan Herbert
Dear Sebastian,
please try what happens, if you put two additional scalars before cpPolynomial. I'm not quite sure, but I think there should be standard enthalpy and entropy of formation be added.
Good luck,
Stefan
Old   June 24, 2010, 16:55
Hi Stefan,
Thank you so much for your help!
But I have got a probleme compiling the new model. This is my error message. It is in german but I think I need not translate it for you .
root@chrisilinux:/media/DATA/Daten/Chrisi_Dokumente/Studium/Masterarbeit/lib/src/thermophysicalModels/basic# wmake libso
Making dependency list for source file mixtures/basicMixture/basicMixture.C
Making dependency list for source file mixtures/basicMixture/basicMixtures.C
Making dependency list for source file basicThermo/basicThermo.C
Making dependency list for source file psiThermo/basicPsiThermo/basicPsiThermo.C
Making dependency list for source file psiThermo/basicPsiThermo/newBasicPsiThermo.C
Making dependency list for source file psiThermo/hPsiThermo/hPsiThermos.C
Making dependency list for source file psiThermo/ePsiThermo/ePsiThermos.C
Making dependency list for source file rhoThermo/basicRhoThermo/basicRhoThermo.C
Making dependency list for source file rhoThermo/basicRhoThermo/newBasicRhoThermo.C
Making dependency list for source file rhoThermo/hRhoThermo/hRhoThermos.C
Making dependency list for source file derivedFvPatchFields/fixedEnthalpy/fixedEnthalpyFvPatchScalarField.C
Making dependency list for source file derivedFvPatchFields/gradientEnthalpy/gradientEnthalpyFvPatchScalarField.C
Making dependency list for source file derivedFvPatchFields/mixedEnthalpy/mixedEnthalpyFvPatchScalarField.C
Making dependency list for source file derivedFvPatchFields/fixedInternalEnergy/fixedInternalEnergyFvPatchScalarField.C
Making dependency list for source file derivedFvPatchFields/gradientInternalEnergy/gradientInternalEnergyFvPatchScalarField.C
Making dependency list for source file derivedFvPatchFields/mixedInternalEnergy/mixedInternalEnergyFvPatchScalarField.C
Making dependency list for source file derivedFvPatchFields/wallHeatTransfer/wallHeatTransferFvPatchScalarField.C
SOURCE=mixtures/basicMixture/basicMixture.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/root/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -I/root/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/basicMixture.o
SOURCE=mixtures/basicMixture/basicMixtures.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/root/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -I/root/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/basicMixtures.o
mixtures/basicMixture/basicMixtures.C:97: Fehler: »polynomialTransport« wurde in diesem Gültigkeitsbereich nicht definiert
mixtures/basicMixture/basicMixtures.C:97: Fehler: »hPolynomialThermo« wurde in diesem Gültigkeitsbereich nicht definiert
mixtures/basicMixture/basicMixtures.C:97: Fehler: falsche Anzahl der Templateargumente (2, sollte 1 sein)
/root/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels/specie/lnInclude/specieThermo.H:49: Fehler: für »template<class thermo> class Foam::specieThermo« bereitgestellt
mixtures/basicMixture/basicMixtures.C:97: Fehler: Templateargument 1 ist ungültig
mixtures/basicMixture/basicMixtures.C:97: Fehler: expected unqualified-id before »,« token
mixtures/basicMixture/basicMixtures.C:97: Fehler: expected unqualified-id before numeric constant
mixtures/basicMixture/basicMixtures.C:97: Fehler: »pureMixturepolynomialTransport3hPolynomialThermo4 perfectGas« has not been declared
mixtures/basicMixture/basicMixtures.C:97: Warnung: Variable »Foam::debug« wird nicht verwendet
make: *** [Make/linuxGccDPOpt/basicMixtures.o] Fehler 1
Have you got an idea where the error comes from?
Regards Chrisi
Old   June 28, 2010, 03:47
Stefan Herbert
Dear Chrisi,
I'm sorry, I've forgotten to mention a detail. You have to include additional files into the header of hPsiThermos.C and basicMixtures.C to define polynomialTransport and hPolynomialThermo, respectivley. Just add
#include "hPolynomialThermo.H"
#include "polynomialTransport.H"
Hope it works now,
Stefan
Old   June 28, 2010, 04:51
Hi Stefan,
Thank you again. Without your help I would have never been able to compile it.
I succeded compiling the new model but first I got this error:
/cfd/externe-ma/Alt/lib/src/thermophysicalModels/basic >wmake libso
SOURCE=mixtures/basicMixture/basicMixture.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/basicMixture.o
SOURCE=mixtures/basicMixture/basicMixtures.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/basicMixtures.o
SOURCE=basicThermo/basicThermo.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/basicThermo.o
SOURCE=psiThermo/basicPsiThermo/basicPsiThermo.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/basicPsiThermo.o
SOURCE=psiThermo/basicPsiThermo/newBasicPsiThermo.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/newBasicPsiThermo.o
SOURCE=psiThermo/hPsiThermo/hPsiThermos.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/hPsiThermos.o
In file included from psiThermo/hPsiThermo/hPsiThermos.C:27:
lnInclude/makeBasicPsiThermo.H:86:2: error: #endif without #if
make: *** [Make/linux64GccDPOpt/hPsiThermos.o] Error 1
Then I removed the endif it complained about, at then it run.
I hope this will not cause a problem later?
But know I try to recompile my solver like you told me. What did you mean with "path to your lnInclude"? Should this be the absolut path? Must it be in "" or not?
At the moment I am getting this error message:
/cfd/externe-ma/Alt/applications/solvers/compressible/rhoPorousSimpleFoam_poly >wmake
Making dependency list for source file rhoPorousSimpleFoam_poly.C
could not open file basicPsiThermo.H for source file rhoPorousSimpleFoam_poly.C
could not open file basicThermo.H for source file rhoPorousSimpleFoam_poly.C
SOURCE=rhoPorousSimpleFoam_poly.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/user/e18980/OpenFOAM/e18980-1.6/lib/"/cfd/externe-ma/Alt/lib/src/thermophysicalModels/basic/lnInclude" -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/cfdTools -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/rhoPorousSimpleFoam_poly.o
rhoPorousSimpleFoam_poly.C:35:28: error: basicPsiThermo.H: No such file or directory
In file included from /cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H:48,
from rhoPorousSimpleFoam_poly.C:36:
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:52:25: error: basicThermo.H: No such file or directory
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:85: error: ISO C++ forbids declaration of ‘basicThermo’ with no type
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:85: error: expected ‘;’ before ‘&’ token
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:107: error: expected ‘,’ or ‘...’ before ‘&’ token
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:107: error: ISO C++ forbids declaration of ‘basicThermo’ with no type
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:130: error: expected ‘,’ or ‘...’ before ‘&’ token
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:131: error: ISO C++ forbids declaration of ‘basicThermo’ with no type
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:142: error: expected ‘,’ or ‘...’ before ‘&’ token
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:143: error: ISO C++ forbids declaration of ‘basicThermo’ with no type
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:172: error: ISO C++ forbids declaration of ‘basicThermo’ with no type
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:172: error: expected ‘;’ before ‘&’ token
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:178: error: expected `;' before ‘const’
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H: In static member function ‘static Foam::autoPtr<Foam::compressible::turbulenceModel> Foam::compressible::turbulenceModel::addturbulence ModelConstructorToTable<turbulenceModelType>::Newt urbulenceModel(const Foam::volScalarField&, const Foam::volVectorField&, const Foam::surfaceScalarField&, int)’:
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:107: error: ‘thermoPhysicalModel’ was not declared in this scope
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H: In member function ‘const Foam::volScalarField& Foam::compressible::turbulenceModel::mu() const’:
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:180: error: ‘thermophysicalModel_’ was not declared in this scope
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H: In member function ‘const Foam::volScalarField& Foam::compressible::turbulenceModel::alpha() const’:
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:186: error: ‘thermophysicalModel_’ was not declared in this scope
In file included from rhoPorousSimpleFoam_poly.C:36:
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H: At global scope:
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H:139: error: expected ‘,’ or ‘...’ before ‘&’ token
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H:139: error: ISO C++ forbids declaration of ‘basicThermo’ with no type
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H:163: error: expected ‘,’ or ‘...’ before ‘&’ token
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H:164: error: ISO C++ forbids declaration of ‘basicThermo’ with no type
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H:175: error: expected ‘,’ or ‘...’ before ‘&’ token
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H:176: error: ISO C++ forbids declaration of ‘basicThermo’ with no type
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H: In static member function ‘static Foam::autoPtr<Foam::compressible::RASModel> Foam::compressible::RASModel::adddictionaryConstru ctorToTable<RASModelType>::New(const Foam::volScalarField&, const Foam::volVectorField&, const Foam::surfaceScalarField&, int)’:
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel/RASModel.H:139: error: ‘thermoPhysicalModel’ was not declared in this scope
In file included from rhoPorousSimpleFoam_poly.C:46:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:3: error: ‘basicPsiThermo’ was not declared in this scope
createFields.H:3: error: template argument 1 is invalid
createFields.H:4: error: invalid type in declaration before ‘(’ token
createFields.H:5: error: ‘basicPsiThermo’ is not a class or namespace
createFields.H:7: error: ‘thermo’ was not declared in this scope
createFields.H:7: error: ‘pThermo’ cannot be used as a function
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:6: warning: unused variable ‘momentumPredictor’
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:9: warning: unused variable ‘fluxGradp’
/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:12: warning: unused variable ‘transonic’
make: *** [Make/linux64GccDPOpt/rhoPorousSimpleFoam_poly.o] Error 1
Old   June 28, 2010, 06:56
Stefan Herbert
Hi Chrisi,
I'm really sorry, but there was still something missing in my first post. I have updated the code for makeBasicPsiThermo.H.
The "path to your lnInclude" should be replaced by the absolute patch to basic/lnInclude. If you followed my suggestion it should look like
-I$(WM_PROJECT_USER_DIR)/lib/thermophysicalModels/basic/lnInclude
Hope it will work now
Stefan
Old   June 28, 2010, 08:50
Sorry its me again.
At first thank you again.
The model compiles perfect now.
I can still not compile my solvers with the new model.
This is my error:
/cfd/externe-ma/Alt/applications/solvers/compressible/rhoPorousSimpleFoam_1 >wclean
/cfd/externe-ma/Alt/applications/solvers/compressible/rhoPorousSimpleFoam_1 >wmake
Making dependency list for source file rhoPorousSimpleFoam_1.C
could not open file basicPsiThermo.H for source file rhoPorousSimpleFoam_1.C
could not open file basicThermo.H for source file rhoPorousSimpleFoam_1.C
SOURCE=rhoPorousSimpleFoam_1.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/user/e18980/OpenFOAM/e18980-1.6/lib/thermophysicalModels/basic/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/RAS/RASModel -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/cfdTools -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/cfd/CFD/PROGRAMME/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/rhoPorousSimpleFoam_1.o
rhoPorousSimpleFoam_1.C:35:28: error: basicPsiThermo.H: No such file or directory
from rhoPorousSimpleFoam_1.C:36:
In file included from rhoPorousSimpleFoam_1.C:36:
In file included from rhoPorousSimpleFoam_1.C:46:
make: *** [Make/linux64GccDPOpt/rhoPorousSimpleFoam_1.o] Error 1
Perhabs I mad a mistake in /make/options in the solver folder. This is my options file:
EXE_INC = \
-I$(WM_PROJECT_USER_DIR)/lib/thermophysicalModels/basic/lnInclude \
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/turbulenceModels/compressible/RAS/RASModel \
-I$(LIB_SRC)/finiteVolume/cfdTools \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
$(FOAM_USER_LIBBIN)/libuserBasicThermophysicalModels.so \
-lspecie \
-lcompressibleRASModels \
-lfiniteVolume \
-lmeshTools
For the thermophysical models a made exactly the procedure like you described with your new additionals.
Can you see a mistake in my options-file?
Regards Chrisi
Old   June 28, 2010, 09:41
Stefan Herbert
Hi Chrisi,
it seems that the error lies here:
because the compiler reports that it couldn't find the source files of thermophysicalModels (error report "could not open ..."). It's hard for me to tell you what exactly you have to type there, but you need to give in the path of your new source files there, so the compiler can read them. For explanation: -I$(WM_PROJECT_USER_DIR) points to your personal folder (e.g. chrisi-1.6/) and starting from there please give in the path to your new source files (or better to their links in basic/lnInclude).
Regards,
Stefan
Old   June 28, 2010, 11:04
Hi Herbert,
thanks.
Now I compiled my solver succesfully. But I get the same error like Sebastian when I try to run the solver. I took exactly your thermophysical properties.
Any ideas?
Best regards
Chrisi
Old   June 28, 2010, 11:09
Hi Herbert,
thanks.
Create mesh for time = 0
Selecting thermodynamics package hPsiThermo<pureMixture<polynomialTransport3<specie Thermo<hPolynomialThermo4<perfectGas>>>>>
Unknown basicPsiThermo type hPsiThermo<pureMixture<polynomialTransport3<specie Thermo<hPolynomialThermo4<perfectGas>>>>>
8
From function basicPsiThermo::New(const fvMesh&)
in file psiThermo/basicPsiThermo/newBasicPsiThermo.C at line 64.
FOAM exiting
Any ideas?
Best regards
Chrisi
Old   June 28, 2010, 11:35
Stefan Herbert
Dear Chrisi,
now I'm totally confused! That means the new model-combinations are not defined and the changes are completely ignored. I have to think about, but I don't think I missed something such elementary in my description! Please have a look on each single step again.
Regards,
Stefan
Old   June 29, 2010, 02:22
I am sorry I made a mistake!!!
Now the solver with the new model is running!!
Thank you so much!
I will keep you up to date about the results!
Best regards
Chrisi
Old   July 6, 2010, 06:47
like promised I want to give an update.
Everything seems to work very well with your new themphysical models.
Thank you once again!!
Best regards
Chrisi
Introducing polynomial thermophysical properties juanltm OpenFOAM Running, Solving & CFD 11 September 22, 2016 12:54
liquid in Thermophysical properties David_010 OpenFOAM 1 January 25, 2012 09:12
polynomial thermophysical properties jason.ryon OpenFOAM 2 May 11, 2011 06:16
thermophysical properties of two different gases arvind_arya OpenFOAM Pre-Processing 1 August 4, 2010 13:04
thermophysical properties of ham Alex Ivancic Main CFD Forum 1 November 5, 1998 11:09
