June 24, 2010, 00:04 |
directMapped-nearestFace doesn't work
Jiang
Rep Power: 16 |
Dear all,
Who has used the nearestFace method in directMapped . My nearestFace doesn't work, but nearestCell works fine. The following is my boundary file set: 5 ( inlet { type directMappedPatch; nFaces 30; startFace 27238; sampleMode nearestFace; sampleRegion region0; samplePatch none; offset ( 0.05 0 0 ); } outlet { type patch; nFaces 57; startFace 27268; } upperWall { type wall; nFaces 275; startFace 27325; } lowerWall { type wall; nFaces 302; startFace 27600; } frontAndBack { type empty; nFaces 27570; startFace 27902; } ) but I have error message : Starting time loop Reading/calculating field UMean Reading/calculating field pMean fieldAverage: starting averaging at time 0 Time = 1e-05 Courant Number mean: 0 max: 0.2 start 27238 out of range 0 ... 29#0 Foam::error:rintStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/printStack.C:203 #1 Foam::error::abort() at ~/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/error.C:242 #2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at ~/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/errorManip.H:87 #3 Foam::UList<Foam::Vector<double> >::checkStart(int) const at ~/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/UListI.H:82 #4 Foam::SubList<Foam::Vector<double> >::SubList(Foam::UList<Foam::Vector<double> > const&, int, int) at ~/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/SubListI.H:61 #5 Foam::List<Foam::Vector<double> >::subList const Foam::fvPatch:atchSlice<Foam::Vector<double> >(Foam::List<Foam::Vector<double> > const&) const at ~/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvPatch.H:191 #6 Foam::directMappedFixedValueFvPatchField<Foam::Vec tor<double> >::updateCoeffs() at ~/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/fields/fvPatchFields/derived/directMappedFixedValue/directMappedFixedValueFvPatchField.C:267 #7 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoef fs() at ~/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/GeometricBoundaryField.C:271 #8 Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) at ~/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMatrix.C:230 #9 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/panda60/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPDebug/libfiniteVolume.so" #10 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/finiteVolume/laplacianSchemes/gaussLaplacianScheme/gaussLaplacianSchemes.C:114 #11 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/laplacianScheme.C:108 #12 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) at ~/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvmLaplacian.C:220 #13 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvmLaplacian.C:252 #14 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvmLaplacian.C:264 #15 Foam::incompressible::LESModels::GenEddyVisc::divD evBeff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ~/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/incompressible/LES/GenEddyVisc/GenEddyVisc.C:95 #16 Foam::incompressible::LESModel::divDevReff(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ~/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/incompressible/LES/LESModel/LESModel.H:240 #17 main at ~/OpenFOAM/OpenFOAM-1.6/applications/solvers/incompressible/pisoFoam/pisoFoam.C:70 #18 __libc_start_main in "/lib/libc.so.6" #19 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 From function UList<T>::checkStart(const label) in file /home/panda60/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/UListI.H at line 78. FOAM aborting Who has ued this ,could give me some suggestions ? Maybe my set is not right. Thanks. |
Display Modes | |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
<unresolved overloaded function type> - How to work with that | bastil | OpenFOAM Running, Solving & CFD | 1 | April 14, 2010 04:57 |
cfx+Fortran cannot work with 2 CPUs on windows PC | lee | CFX | 1 | May 8, 2006 11:36 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 13:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 22:03 |
