-   -   LES of a square cylinder (http://www.cfd-online.com/Forums/openfoam-solving/77489-les-square-cylinder.html)
gfilip June 24, 2010 10:22
2 Attachment(s)
I am having what I presume are inlet or grid quality issues with an LES case for a square cylinder. As can be seen in the attached images, the inflow to the left of the cylinder shows a strange behaviour with a variation of U (in attached image, coloured by U mag). My initial guess was that the aspect ratio or the grid quality overall is not good enough for LES. My grid does pass all checks inside of checkMesh.
I am using the dynamic Smagorinsky model (simple filter and cubeRootVol delta) with a hex + polyhedra (due to local refinement) grid of ~1.6 million cells. The Re = 22,000 and y+ average = ~6 after approximately 20 non-dimensional flow-overs, which I presume could be an issue as well as I am using the nuSgsWallFunction on the cylinder wall patch. I will try to construct a y+=1 grid and avoid the use of wall functions next.
My nuSgs file:
dimensions      [0 2 -1 0 0 0 0];
internalField  uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    sides
        type            cyclic;
    cyl
//        type            zeroGradient;
        type            nuSgsWallFunction;
        value          uniform 1;
    sym
        type            symmetryPlane;
And my 0/U file:
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (0.022 0 0);
boundaryField
    cyl
        type            fixedValue;
        value          uniform (0 0 0);
    inlet
        type            fixedValue;
        value          uniform (0.022 0 0);
    outlet
        type            zeroGradient;
    sides
        type            cyclic;
    sym
        type            symmetryPlane;
Is my setup incorrect, or is this purely a grid issue? Any hints would be greatly appreciated.
-Grzegorz
lakeat June 24, 2010 12:33
Sorry, but I have to say your mesh looks bad, and is better not be called LES.
And what's more, it seems your inlet has a velocity profile, that's strange, isn't it?
You can upload your case file in tgz format, so that we could have a look, we need 0/ constant/ system/
