strange error !! ?
Old   April 26, 2011, 11:07
Default strange error !! ?
T.D. is on a distinguished road
hello foamers,
i got this error:
Courant Number mean: 0.0385444 max: 0.375189
Time = 0.0006
DILUPBiCG: Solving for Yxx, Initial residual = 0.435933, Final residual = 0.000352135, No Iterations 1
DILUPBiCG: Solving for Yxy, Initial residual = 0.561611, Final residual = 0.000503692, No Iterations 1
DILUPBiCG: Solving for Yyx, Initial residual = 0.561611, Final residual = 0.000503692, No Iterations 1
DILUPBiCG: Solving for Yyy, Initial residual = 0.450155, Final residual = 0.000397833, No Iterations 1
DILUPBiCG: Solving for Yzz, Initial residual = 0.43693, Final residual = 0.000350972, No Iterations 1
DICPCG: Solving for Ux, Initial residual = 0.253196, Final residual = 0.000966861, No Iterations 1
DICPCG: Solving for Uy, Initial residual = 0.555223, Final residual = 0.00149786, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.99094, Final residual = 0.0445036, No Iterations 3
time step continuity errors : sum local = 0.00476051, global = -4.95985e-20, cumulative = 2.38877e-19
DILUPBiCG: Solving for c, Initial residual = 0.999999, Final residual = 7.19379e-06, No Iterations 2
DILUPBiCG: Solving for Yxx, Initial residual = 0.120848, Final residual = 7.86743e-05, No Iterations 1
DILUPBiCG: Solving for Yxy, Initial residual = 0.195984, Final residual = 0.000106254, No Iterations 1
DILUPBiCG: Solving for Yyx, Initial residual = 0.195984, Final residual = 0.000106254, No Iterations 1
DILUPBiCG: Solving for Yyy, Initial residual = 0.103711, Final residual = 4.32296e-05, No Iterations 1
DILUPBiCG: Solving for Yzz, Initial residual = 0.119823, Final residual = 7.54162e-05, No Iterations 1
DICPCG: Solving for Ux, Initial residual = 0.241468, Final residual = 0.00109022, No Iterations 1
DICPCG: Solving for Uy, Initial residual = 0.131006, Final residual = 0.00042547, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.991567, Final residual = 0.0423, No Iterations 3
time step continuity errors : sum local = 0.00575673, global = 6.13115e-20, cumulative = 3.00189e-19
DILUPBiCG: Solving for c, Initial residual = 1, Final residual = 1.94518e-05, No Iterations 2
ExecutionTime = 0.06 s ClockTime = 0 s
Courant Number mean: 0.0246895 max: 0.152726
Time = 0.0007
DILUPBiCG: Solving for Yxx, Initial residual = 0.1414, Final residual = 3.40682e-06, No Iterations 2
DILUPBiCG: Solving for Yxy, Initial residual = 0.0985113, Final residual = 3.19704e-05, No Iterations 1
DILUPBiCG: Solving for Yyx, Initial residual = 0.0985113, Final residual = 3.19704e-05, No Iterations 1
DILUPBiCG: Solving for Yyy, Initial residual = 0.116681, Final residual = 9.3886e-05, No Iterations 1
DILUPBiCG: Solving for Yzz, Initial residual = 0.14354, Final residual = 3.20418e-06, No Iterations 2
DICPCG: Solving for Ux, Initial residual = 0.262215, Final residual = 0.00136479, No Iterations 1
DICPCG: Solving for Uy, Initial residual = 0.0803584, Final residual = 0.000363007, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.991556, Final residual = 0.0396851, No Iterations 4
time step continuity errors : sum local = 0.00644659, global = 4.19326e-19, cumulative = 7.19515e-19
DILUPBiCG: Solving for c, Initial residual = 1, Final residual = 0.000109326, No Iterations 2
DILUPBiCG: Solving for Yxx, Initial residual = 0.0930615, Final residual = 9.10629e-06, No Iterations 2
DILUPBiCG: Solving for Yxy, Initial residual = 0.0546977, Final residual = 1.03868e-06, No Iterations 2
DILUPBiCG: Solving for Yyx, Initial residual = 0.0546977, Final residual = 1.03868e-06, No Iterations 2
DILUPBiCG: Solving for Yyy, Initial residual = 0.0796056, Final residual = 3.40886e-06, No Iterations 2
DILUPBiCG: Solving for Yzz, Initial residual = 0.0927054, Final residual = 8.43796e-06, No Iterations 2
DICPCG: Solving for Ux, Initial residual = 0.683065, Final residual = 0.0029376, No Iterations 1
DICPCG: Solving for Uy, Initial residual = 0.520303, Final residual = 0.00155573, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.999646, Final residual = 0.0290902, No Iterations 2
time step continuity errors : sum local = 0.0215899, global = 2.45569e-19, cumulative = 9.65084e-19
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libfiniteVolume.so"
in "/home/talib/OpenFOAM/talib-1.7.1/applications/bin/linuxGccDPOpt/TalibicoFoamFrancoisframeInvariantTwoSenses"
#6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Floating point exception
any ideas ??
T.D. is offline   Reply With Quote
Old   April 26, 2011, 11:32
Bernhard
Bernhard is on a distinguished road
You're not very specific, but it looks like you have a divergence in solving the equation for c.
Bernhard is offline   Reply With Quote
Old   April 26, 2011, 11:59
Default Solver with case attached
Hi Bernhard, thanks,
I attached the solver with the case.Must only compile before run.
I tried different types of solvers, and different relaxation factors, but without success to converge.
If anyOne can look at, or even try ?
really, thanks a lot
Best Regards,
T.D.
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 09:27
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
user defined function cfduser CFX 0 April 29, 2006 10:58
