January 24, 2008, 07:28 |
I'm wondering anyone kn
Erik Arlemark
Rep Power: 17 |
I'm wondering anyone knows if the Exponential integral function is implemented in OpenFOAM. If not, maybe someone can give me a hint of how to implement it in my solver myself? Thanks /Erik |
January 24, 2008, 15:04 |
hi,
isnt there are expansio
Stephan Gerber
Rep Power: 17 |
hi,
isnt there are expansion of this integral (at least for special arguments like pure complex or real..)?? just wondering stephan |
January 25, 2008, 06:11 |
Hi Erik,
I don't know if it
George Kokotis
Rep Power: 17 |
Hi Erik,
I don't know if it would be of any use to you, but I have used in the past some asymptotic methods to approximate exponential integrals. Relevant methods are described in the following book: Title: Asymptotic Expansions Author: A. Erdelyi Publisher: Dover Publications (June 1, 1956) ISBN-10: 0486603180 ISBN-13: 978-0486603186 At that time (1993), direct calculation was numerically heavy, involving (if I am not mistaken) reformulation of the integrand in terms of Bessel functions and direct numerical integration... On what field are you working? |
January 25, 2008, 06:44 |
Hi George,
Thank you very m
Erik Arlemark
Rep Power: 17 |
Hi George,
Thank you very much for the reference! Im working on micro gas flows and I want to incorporate a geometry dependent viscosity (varying with wall-distance) based on viscosities dependence on the mean free path (MFP) (which with physical reasoning also should vary with wall-distance). The thing is: An established expression of this effective mean free path is formulated using the exponential integral (Ei). I have derived a similar and approximate formulation of the geometry dependent MFP which only uses functions known to OpenFOAM. So if the Ei function isn't defined I'm actually happy because it means an numerical advantage for my model (even if approximate). Thank you /Erik |
July 2, 2010, 15:13 |
Rep Power: 15 |
I currently have the same problem. I have to use the exponential integral function but I can't find out how to integrate it to my C programme. I've tried "::Ei" but it didn't work. Is there a special library to include at the beginning? How did you manage to solve tour case? Thank you to answer because I'm really stuck. Ingrid |
Maximum Pre-Exponential Factor? | Carl | FLUENT | 0 | February 1, 2009 23:01 |
How to Include Exponential in UDF | RL | FLUENT | 5 | September 11, 2008 17:51 |
udf/exponential | ssixr | FLUENT | 4 | September 6, 2008 00:25 |
monitor surface integral & report surface integral | Ning | FLUENT | 0 | March 18, 2007 12:51 |
Exponential Cell Spacing | pandelis chatzis | Siemens | 1 | July 25, 2002 14:42 |
