Warning message
Old   July 13, 2010, 10:10
Default Warning message
stephane sanchi
openfoam_user is on a distinguished road
Hello OF-users,
I have the following warning message when I launch a case:
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName& functionLibName)
in file db/dlLibraryTable/dlLibraryTable.C at line 78
could not load libparMetisDecompositionMethod.so: cannot open shared object file: No such file or directory
I get the same message when I launch decomposePar.
The decomposition works and the case runs well (I think) but why this warning message.
Regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   July 13, 2010, 10:35
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Did you recently upgrade to 1.7?
in system/controlDict you have a line that reads
libs ( "libParMetisDecompositionMethod.so" );
Thats what it complains about. Nothing that will produce more than a
warning when it cant find the lib, bit if you want to get rid of it, it
should be changed to
libs ( "libParMetisDecomp.so" );
Originally Posted by openfoam_user View Post
Hello OF-users,
--> FOAM Warning :
Regards,
Stephane.
niklas is offline   Reply With Quote
Old   July 13, 2010, 11:02
stephane sanchi
Thanks, it works.
Now the warning message has disappeared.
Stephane.
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 19:53
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
