"floating point exception" what does it mean? |
July 16, 2010, 09:36 |
Muhammad reza hassani
Rep Power: 16 |
hi
I wanted to solve a problem of a non-Newtonian fluid through an expansion. I set a timeVaryingInletOutlet at the inlet for velocity and a time series for pressure at the outlet using timeVaryingFixedValue. viscosity model is BirdCarreau. I do not know what the problem is but the thing printed in the terminal is: Courant Number mean: 0 max: 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 6.02929e-07, No Iterations 19 DILUPBiCG: Solving for Uy, Initial residual = 0.999937, Final residual = 7.89022e-07, No Iterations 19 DICPCG: Solving for p, Initial residual = 1, Final residual = 4.95431e-07, No Iterations 210 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::fv::gaussGrad<double>::grad(Foam::GeometricF ield<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so" #4 Foam::fv::gaussGrad<double>::grad(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so" #5 Foam::fv::correctedSnGrad<double>::correction(Foam ::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so" #6 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so" #7 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so" #8 in "/opt/openfoam170/applications/bin/linuxGccDPOpt/nonNewtonianIcoFoam" #9 in "/opt/openfoam170/applications/bin/linuxGccDPOpt/nonNewtonianIcoFoam" #10 in "/opt/openfoam170/applications/bin/linuxGccDPOpt/nonNewtonianIcoFoam" #11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #12 in "/opt/openfoam170/applications/bin/linuxGccDPOpt/nonNewtonianIcoFoam" Floating point exception anyone knows how I can fix the problem? |
movingConeMotion with "Floating point exception" crashed!! | quinton | OpenFOAM | 1 | September 3, 2009 19:56 |
CFX error, "Floating point exception" | moca | CFX | 8 | July 23, 2009 07:58 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
