pisoFOAM & k-w-SST
Old   July 24, 2010, 09:02
Default pisoFOAM & k-w-SST
Christos
T3rmInAt0r is on a distinguished road
Hello guys,
I am trying to solve the very trivial lid-driven cavity flow case with water but I face some problems. The flow is turbulent with cavity dimensions 1 x 1 x 1 (m) and lid speed 0.010048 (fixed to Re=10000).
Although I had changed every reference to epsilon (files taken from the tutorial) with omega. I can't run the case.
Could you propose me anything?
I have put omega (as replica of epsilon substituting every "epsilon" with omega) within the ./0/
also in ./system/ I have changed fvSchemes with the same way.
in ./constant I had writter RANSkOmega (although I am kind of sure that it should be something else, but I didn't find any other reference on the net)
I miss some important factors but I don't know which
Any kind of help is highly appreciated!!!
Thanx in advance,
Termy
T3rmInAt0r is offline   Reply With Quote
Old   July 26, 2010, 02:57
Stefan Herbert
herbert is on a distinguished road
You need two define
simulationType     RASModel;
in ./constant/turbulenceProperties and
RASModel            kOmegaSST;
turbulence           on;
in ./constant/RASProperties. Then it should work.
Regards,
Stefan
herbert is offline   Reply With Quote
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam mchurchf OpenFOAM 7 August 6, 2023 09:12
Understanding k-omega SST model source code tmhonka OpenFOAM Programming & Development 1 September 8, 2009 07:33
YPlus Values and SST Model Jenny CFX 1 June 22, 2008 18:47
why SST model??? vijay CFX 3 May 22, 2008 03:05
Swirling flow in a diffuser: K-E over SST ? Felix CFX 3 February 27, 2007 21:03
