Flow Over a cylinder: Properties not conserved
Old   July 23, 2010, 10:44
Default Flow Over a cylinder: Properties not conserved
jeff osborne
ozzythewise is on a distinguished road
Hello all,
I am trying to simulate flow over a cylinder for a validation as I am new to CFD. I am simulating at a Reynolds number of 150. Essentially what happens is everything is going fine, and then after a certain amount of time, all the flow properties (U and p in this case) skyrocket and the simulation crashes. I have attached a few pictures of the simulation that may help explain what is happening. Below is also a printout of my U and p files respectively:
Velocity File:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (11.76e-4 0 0); //Re=150 for Air
boundaryField
inlet
type fixedValue;
value uniform (11.76e-4 0 0);
backOutlet
type zeroGradient;
cylinder
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
topOutlet
type fixedValue;
bottomOutlet
type fixedValue;
Pressure File:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type fixedValue;
value uniform 0;
backOutlet
type zeroGradient;
cylinder
type zeroGradient;
frontAndBack
type empty;
topOutlet
type fixedValue;
value uniform 0;
bottomOutlet
type fixedValue;
value uniform 0;
ozzythewise is offline   Reply With Quote
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Simulation Flow Around cylinder 3D Jwolf CFX 19 November 25, 2009 14:21
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
axial flow around a cylinder -heat transfer model? Ralf Schmidt Main CFD Forum 1 March 21, 2006 08:54
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
