-   OpenFOAM Running, Solving & CFD (
-   -   pisoFOAM & k-w-SST (
T3rmInAt0r July 24, 2010 09:02
pisoFOAM & k-w-SST
Hello guys,
I am trying to solve the very trivial lid-driven cavity flow case with water but I face some problems. The flow is turbulent with cavity dimensions 1 x 1 x 1 (m) and lid speed 0.010048 (fixed to Re=10000).
Although I had changed every reference to epsilon (files taken from the tutorial) with omega. I can't run the case.
Could you propose me anything?
I have put omega (as replica of epsilon substituting every "epsilon" with omega) within the ./0/
also in ./system/ I have changed fvSchemes with the same way.
in ./constant I had writter RANSkOmega (although I am kind of sure that it should be something else, but I didn't find any other reference on the net)
I miss some important factors but I don't know which
Any kind of help is highly appreciated!!!
Thanx in advance,
herbert July 26, 2010 02:57
You need two define
simulationType    RASModel;
in ./constant/turbulenceProperties and
RASModel            kOmegaSST;
turbulence          on;
in ./constant/RASProperties. Then it should work.
