Home > Forums > OpenFOAM Running, Solving & CFD
blowing up with k-epsilon model
Like Tree1Likes
Old   August 5, 2010, 04:56
Sebastian Saegeler
sebastian is on a distinguished road
Hello!
Thank you a lot for all your advices. I think it will take me a while untill I have tested it all.
But I dont really understand this expression :
Gauss linearUpwind cellLimited Gauss linear 1;
Can you explain me the the meaning of it, what it does?
Over night I run a calculation where I have changed the fixed values at the inlets for k and epsilon. I looked into the fluent solution, where I have variable BCs according to turbulent viscosity ratio and turbulent intensity. Now what I did is, I took the values from there and changed the one in OF. Then I continued the calculation from it500 and it didnt diverge at it600. Its still running and now I am at it 2000. Still have the bounding problem, but at least its running.
So I also expect its not good to use the fixedValue bc at the inlets for k and epsilon. I already tried to use the "turbulentIntensityKineticEnergyInlet" and the "turbulentMixingLengthDissipationRateInlet". But as mentioned, the calculation crashes after only a few iterations.
No idea want went wrong. Can anybody have a look at my case. You will find my bc for k and epsilon in /0. The files are epsilon.functions and k.functions.
Thanks!!
Sebastian
sebastian is offline   Reply With Quote
Old   August 5, 2010, 05:06
Christian Lucas
Chris Lucas is on a distinguished road
just a short remark. In the epsilon inlet function you used the wrong length. The length has to be given in meter not mm.
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   August 5, 2010, 09:27
Sebastian Saegeler
Hi Christian!
Of course, youre right, i forgot the e-3 behind the values.
Now it starts calculating and at least its still running
But for the turbulentIntensityKineticEnergyInlet something still is going wrong!
I have calculated the initial values like this:
Initial U=10 m/s, turbulence intensity is 5%, so: k=3/2(0,05*10)^2=0.325 ... and so on.
Here, thats my k file, maybe anybody has an idea:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.0001;
boundaryField
core_inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.05; // 5% turbulence
value uniform 0.375;
fan_inlet
farfield_inlet
intensity 0.001; // 0.1% turbulence
value uniform 1.5e-4;
walls
type kqRWallFunction;
value uniform 1;
farfield_outlet
type zeroGradient;
If I do initialize everything with k=1, and also set the bc at the inlet to this fixed value, its running.. but thats not a good way to do so..
I am also not so sure about, if I have set the turbulent lenght scales correctly in my turbulentMixingLengthDissipationRateInlet bc.
At the Inlets of my core and fan stream, I just said its 5% of my channel height. At the Inlet of my farfield, I also used 5% of my domain height. Do you think thats a reasonable guess??
I would be pleased if I get some further help of you!! Thanks a lot!
Sebastian
Old   September 18, 2010, 09:04
Default units turbulentMixingLengthDissipationRateInlet
  #24
Patty
ptbs is on a distinguished road
Hi
I am not a specialist but having the same problem (blowing up)
I had a look at Sebastian 0/e file and he mentioned a factor
turbulentMixingLengthDissipationRateInlet = 15 with a comment //15mm
In the following web reference
/html/classturbulentMixingLengthDissipationRateInletFvPa tchScalarField.html
it is said the units to be specified are meter (and not mm). Are you sure of your units? it would change drastically the turbulence isn't it?
Have you a comment? did you solve your problem? how?
Best regards
ptbs is offline   Reply With Quote
Old   September 18, 2010, 09:17
maddalena's Avatar
maddalena
maddalena is on a distinguished road
Originally Posted by ptbs View Post
it is said the units to be specified are meter (and not mm). Are you sure of your units? it would change drastically the turbulence isn't it? Have you a comment? did you solve your problem? how?
this has been already pointed out and solved! look here.
cheers
mad
maddalena is offline   Reply With Quote
Thread Tools
Trackbacks are On
Nonlinear k epsilon Shih Model idrama OpenFOAM 9 August 30, 2010 09:37
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 04:19
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 04:37
K-Epsilon Model sangit Main CFD Forum 2 September 9, 2004 13:19
