OF Compressible Solver Errors- BC Related
Hi Foamers,
Ive been using OpenFOAM for nearly a year with moderate success but Ive encountered an issue using the compressible solvers. Ive create a mesh using snappyhexmesh ~1.65million cells which runs fine using simpleFoam. Its a rectangular mesh around a rocket. My issue is that once transferred to any compressible solvers (ive tried this in 1.4.1, 1.6 and 1.7 with the same mesh) I get errors during the initialisation. Unfortunately I cannot post my mesh on here its ~500mb but the yPlus has an average of 54 and i'm happy with it- i dont believe the erros stem from it. The latest error I've got is: (using rhoSonicFoam & kOmegaSST on 1.7.0) Create time Create mesh for time = 2 Reading thermodynamicProperties Reading field p Reading field T Reading field U #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 void Foam::divide<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<Foam::Vector<d ouble>, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam170/applications/bin/linuxGccDPOpt/rhoSonicFoam" #4 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<Foam::Vector<d ouble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam170/applications/bin/linuxGccDPOpt/rhoSonicFoam" #5 in "/opt/openfoam170/applications/bin/linuxGccDPOpt/rhoSonicFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 in "/opt/openfoam170/applications/bin/linuxGccDPOpt/rhoSonicFoam" Floating point exception All the errors follow a similar theme of aborting at either reading U or selecting the turbulence model (rhoSimple in 1.6 and 1.4.1), and ending with "Floating point exception". I have a feeling its to do with my BC but I cannot find anything wrong with them. Here are my BC (please note I only just put the wall functions on k and omega to see if it would make a difference... it didnt): k dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.09375; boundaryField { inlet { type fixedValue; value uniform 0.09375; } outlet { type zeroGradient; } sighter_SIGHTER_BLUNT_ASSEM { type kqRWallFunction; value uniform 0.559; } top { type symmetryPlane; } base { type symmetryPlane; } } Omega dimensions [0 0 -1 0 0 0 0]; internalField uniform 0.559; boundaryField { inlet { type fixedValue; value uniform 0.559; } outlet { type zeroGradient; } sighter_SIGHTER_BLUNT_ASSEM { type kqRWallFunction; value uniform 0.559; } top { type symmetryPlane; } base { type symmetryPlane; } } p dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } sighter_SIGHTER_BLUNT_ASSEM { type zeroGradient; } top { type symmetryPlane; } base { type symmetryPlane; } } U dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0 -50 0); } outlet { type zeroGradient; } sighter_SIGHTER_BLUNT_ASSEM { type fixedValue; value uniform (0 0 0); } top { type symmetryPlane; } base { type symmetryPlane; } } nut dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } sighter_SIGHTER_BLUNT_ASSEM { type nutWallFunction; value uniform 0; } top { type symmetryPlane; } base { type symmetryPlane; } Any ideas would be great. Thanks in advance Andrew |
Try initializing everything with non-zero value. I see that your pressure and velocity is set to zero in "internalfield".
Thanks for that. You were right, changing pressure and velocity fixed it all up!
Andrew |
