Home > Forums > OpenFOAM Running, Solving & CFD
bubbleFoam validation case
Like Tree1Likes
Old   August 30, 2010, 01:58
Alberto Passalacqua
Originally Posted by balkrishna View Post
Thanks for the link .... Can i get the source code of the solver ?? The implementation of the algorithm is the tough aspect in OpenFOAM .....
Try to contact the Authors of the paper. I believe the code was not released, and it is surely not part of OpenFOAM and OpenFOAM-dev/-ext.
Best,
Alberto Passalacqua
GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats.
Old   August 30, 2010, 02:11
Balkrishna Patankar
balkrishna is on a distinguished road
Ok .... Thanks
balkrishna is offline   Reply With Quote
Old   August 30, 2010, 03:05
Alberto Passalacqua
Ok .... Thanks
I can give you some hints which are not explained anywhere in the OF documentation (top secret! ), and are quite useful to carry around a lot of fields, as required in multiphase simulations.
Let's assume you have N phases. You will have to define:
- N momentum equations (N velocity fields and N fvVectorMatrices)
- N*(N-1)/2 interaction fields (meaning relative velocities, drag coefficients, ...)
- N-1 phase fraction equations (assuming one fraction is computed as alpha_0 = 1-sum(alpha_i), i != 0. You will need N phase fraction fields for this.
- 1 pressure equation based on the mixture
As you can easily imagine, if N is arbitrary, coding this can be messy, if not done with proper care.
You can collect your phase fields and equations (also objects if you want) for each property in a PtrList (http://foam.sourceforge.net/doc/Doxy..._1PtrList.html).
I will give you an example for the relative velocity fields:
First define:
const nUr = N*(N-1)/2;
You can define
PtrList<volScalarField> Ur(nUr);
Then, each field has to be actually initialized with
forAll (Ur, urI)
    Ur.set
       urI,
       yourFieldInitialization
To access the relative velocity of index i, you simply have to use
Ur[i]()
Note the (), because you are actually working with a PtrList now, so you have to invoke the corresponding method that returns the field (or a reference to it)!
The same operation can be done with equations:
PtrList<fvVectorMatrix> UEqn(N);
forAll (UEqn, uEqnI)
    UEqn.set
         fvm::ddt(U())
To solve, you loop again over the PtrList, and for each equation, you have to do
solve (UEqn[uEqnI]() == ...);
More good news! If you consider twoPhaseEulerFoam, instead than bubbleFoam, which is actually a bit more ready to be extended to N phases, you will notice that all the properties of a phase are collected in the phaseModel object.
Of course you can create a ptrList of the phaseModel object, and further simplify your work. If you decide to do this, I would suggest to incorporate alpha in the phaseModel, since it is currently not there, or you have an inconsistent syntax that becomes annoying with many phases.
Last hint: since you are beginning with OpenFOAM from what I read, proceed step by step, and ask questions (poking me by email is allowed too, I do not bite , and I usually answer if I can).
Best,
sharonyue likes this.
Alberto Passalacqua
Old   August 30, 2010, 03:42
Balkrishna Patankar
thats clean .... i was about to write python programs to output the necessary files .... In that way , I can take the user input and just write out the files . However the approach requires the compilation of the source code evrytime you specify different number of components ....
Old   August 30, 2010, 04:37
Alberto Passalacqua
No
You simply have to read the number of phases from a dictionary (label nPhases, being it integer), before allocating the PtrList objects ;-)
Something similar is done in OF for the species in reacting solvers, and in multiphaseInterFoam, but in this last solver the implementation of what they called mixture class abuses a bit of C++ functionality, making the code quite unreadable (never a good idea!).
Best,
Alberto Passalacqua
bubble, bubblefoam, foam
Thread Tools
Trackbacks are On
Comparison of axisymmetric case, Starccm+ and OpenFOAM linnemann OpenFOAM Running, Solving & CFD 12 June 16, 2011 05:43
Need help to open an OpenFoam case with Paraviw aaurouss OpenFOAM 2 July 6, 2009 13:18
Validation Case Ruben Main CFD Forum 0 November 1, 2005 11:50
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 03:03
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 03:02
